That's my setup, will i get any problems with the Glossy panel?
if Is it is the case, are these bearable? or are they quite annoying?
That lamp is the only light that i have on in my room at night.
Yes. Huge problems. The lamp needs to be behind the display. Maybe you can turn it and have it point at the wall behind the monitor instead.
Recognized it immediately; I've played too many adventure games to count.
It is quite reflective. During the day, I close the curtains. I don't darken the room or anything. I just avoid direct light on the screen.
Reflections are visible in black areas of the screen. If nothing is black, then reflections don't stand out much. What you really should avoid though is direct lighting on the screen.I've seen videos/reviews of this panel, having the room much more lightened than my room at night, and i didnt see any major reflections at all, only if you put something really close to the panel.
I don't mind the reflections. It's up to you. It's a trade off. Glossy panels have more reflections, but the image is clearer. Personally I was also worried about reflections, but it turned out to be fine with me and the extra image clarity is something I really like.If Glossy panel, in my case will perfom really badly, should i try to switch to this one?
No idea. But when I bought this monitor, a month later the price was cut by 100€
https://tftcentral.co.uk/news/differenc ... -explainedDreamer19 wrote: ↑23 Sep 2024, 13:23So i've been doing a lot of research these days.
Found out that there's an oled glossy monitor 360hz for the same price than the asus.
The only question is, do you guys know, if there is any difference between these two?
https://www.amazon.es/MSI-QD-OLED-Monit ... s_li_ss_tl
https://www.amazon.es/MSI-271QPX-QD-OLE ... ss_tl&th=1
So far, they seem equal, but the "mag" version is much more cheaper, do you guys know why?
