I thought you flashed a new BIOS, with a new uefi gop, then it would make sense.unconnected wrote: ↑27 Sep 2024, 11:30Mine solution is quite case-specific as I had black screen after EVGA vbios thru PX1 update, no harm in trying tho, but make sure the vbios is the same as your old one (you can flash other vendor vbios but beware of the limits, like you cannot flash a galaxy hof 1000W power limit on a palit as it will explode probably).
1) Dump your current vbios thru GPU-Z by clicking to the arrow button after the bios number.
2) Search up your same vbios or an update of it on TechPowerUp library - here's the link of evga 3080ti based on your gpu model and vendor or navigate thru GPU-Z
3) Download NVFlash and extract in a folder with an easy patch
4) Disable your gpu from device manager
For the rest I'd advice to watch this video as he explains what to do in case of incompatible vbios and artifacts.
I actually flashed the same vbios over again but downloaded from the techpowerup library instead of my dump.
Version 94.02.71.80.86
But since you flashed the old BIOS, it means that you just reinstalled the driver.
