FreeSync Flickering problem
hazelfolk
Post by hazelfolk » 02 Oct 2024, 02:13
Hello,
I experienced noticeable flickering on my MSI MAG341CQP QD-OLED monitor when FreeSync was enabled, particularly in game menus, during loading screens, and in darker scenes. The flickering was also present during small frame time fluctuations while gaming, and seemed to worsen in visually dark areas.
I tried tested different frame rate caps like 120Hz and 144Hz, but no luck. Any advice for solution?
Thanks in advance!
Re: FreeSync Flickering problem
Post by RealNC » 02 Oct 2024, 04:26
There is no solution other than trying a cap that can stabilize frame times. The frame limiter needs to be accurate. RTSS is accurate. The Nvidia control panel limiter is accurate as well. I don't know about the AMD control panel limiter. In-game limiters are usually less accurate.
hazelfolk
Post by hazelfolk » 02 Oct 2024, 22:40
I got it. Thanks!
