Eyestrain: in search of high-resolution gaming display
There are over 100 ergonomic issues from displays, far more than just flicker and blue light. This forum covers the giant variety of display ergonomics issues.
grillnola
Post by grillnola » 03 Oct 2024, 10:30
Hello,
I am in search of a high-resolution gaming display that won't cause significant eyestrain: Here are the displays that I have tried that have caused eyestrain for me in the past:
AW2725DF - QD OLED (Felt like I could use any display I wanted until I used this for about a month and my "problems" started)
LG 27GS95QE - WOLED - currently own, 3 days... is acclimation a possibility?
LG 32GS95UE - WOLED
LG 27GR93U - IPS
Iphone 15 - AMOLED
Here are devices that I currently use that do not cause me any eyestrain:
ASUS PG24QP - E-TN
DELL U2719D - IPS
Sony A80K - OLED
LG CX - OLED
Iphone SE Gen 3 - IPS
I wish it was "one thing" and then it would be easier to narrow down, but I am bothered by certain modern IPS and modern OLED panels seemingly. I have recently had a vision test, and everything came back normal (I have myopia, but my prescription is current) Any ideas? I dug around but I really couldn't find a "through line" as to why some of these displays bother me and others don't? The only theories I have are:
1. I am bothered by QD-OLED specifically
2. I am bothered by new MLA WOLED but not standard WOLED? (could the coatings be to blame?)
3. I am bothered by modern KSF phosphor, but possibly not (what were) typical IPS backlights?
Any insight, thoughts, ergonomic suggestions, acclimation tips, etc are much appreciated, as I am at a bit of a loss at this point.
Thanks!!
kyube
Re: Eyestrain: in search of high-resolution gaming display
Post by kyube » 03 Oct 2024, 13:04
grillnola wrote:
03 Oct 2024, 10:30
Hello,
LG 32GS95UE - WOLED
LG 27GR93U - IPS
Iphone 15 - AMOLED
ASUS PG24QP - E-TN
DELL U2719D - IPS
Sony A80K - OLED
LG CX - OLED
Thanks!!
Both the LG & A80K are RWBG OLED's, could be the distance you sit from your A80K, which makes it work for you.
The PG248QP is a KSF-phosphor backlight display, so I don't think it's KSF phosphor you have an issue with.
It could very well just be a NanoIPS issue. The mechanism of NanoIPS displays causing the eyestrain is a unexplored topic from my knowledge.
If you want something high resolution, non-KSF, take a look at the Q24G2A (23.8" 2.5k 165hz) or EX3210U (QD-LED, 32" 4k 144Hz)
