Asus XG27AQDMG Discussion
Glory2Ukraine
Re: Asus XG27AQDMG Discussion
XG27AQDMG Firmware update MCM103:
Bug fixed:
1, Resolved issue with Aspect Control disabled on HDMI sources when Anti-Flicker enable.
2, Fixed the issue where BLF/ Pixel Clean Reminder is still functioning when closed.
3,Fixed the abnormal issue when shadow boost selects dynamic adjustment.
4,Fixed DDCCI function string for DWC functions can operate mormally.
When updating my fw to MCM102 my first USB stick did not work, but tested another USB stick and no problem.
I will update to MCM103 later this week and report back.
Bug fixed:
Glory2Ukraine
Updating to MCM103 using a USB-stick worked without any issues.
- Smallsee
after reinstalling the gpu driver in this section missing hdr certification, only after reinstalling the monitor driver does the certificate appear. additionally the icc profile appears, this certificate affects something?
- 222.png (23 KiB) Viewed 10625 times
Shifroval
Does XG27 model have the same issue with red/orange lighting in 6500K hdr like its predecessor PG27AQDM?
It's not allowed to post links here, but just search rog asus forums for "PG27AQDM HDR looks bad with orange colours".
After MCM107 it's not that glaring like in this thread, but still there. Couldn't find such comparison anywhere, so I'm asking here. Just find a place in any game with torches or fireplace, where it's the only lighting source and all surfaces around the source will be either smeared with brownish mush or slightly purple. I have a PG27 myself, but have an opportunity to buy XG27 and if this issue is not that apparent there or altogether absent, then I'll happily upgrade.
Just in case I have some old jxr screenshots of such lighting in Dragon Age Inquisition that can be easily compared by making a photo of the screen in hdr mode.
- RealNC
I haven't noticed anything, but I don't use HDR much. I used it like 5 times total just to see how it looks in various games and didn't like it because of the excessive brightness.
If you have some specific test in mind (like an HDR video test,) I can do it.
Shifroval
Video is a bit tricky, best if you just load the same area in the same game and with the same angle, but it's very difficult to replicate, since you may not own the games I have, the area is in a very specific spot, etc.
I still have two jxr screenshots from Inquisition with a very orange lighting, I opened them with standard windows image viewer and made a photo of the screen with hdr on and off. I can't attach or link jxrs here or even pm them to you, since I'm new here. How can I send them to you? They're 32mb each. Also I can't attach any photos here. How do I even send anything here if all external links are not allowed and attachments don't work?
- RealNC
You can post links like this: "google dot com"Shifroval wrote: ↑04 Oct 2024, 13:49Video is a bit tricky, best if you just load the same area in the same game and with the same angle, but it's very difficult to replicate, since you may not own the games I have, the area is in a very specific spot, etc.
Shifroval
Yeah, I realized I can do it yesterday (lost technology of link scrambling lol), but it was too late to edit the post for it to make sense.RealNC wrote: ↑05 Oct 2024, 06:20You can post links like this: "google dot com"Shifroval wrote: ↑04 Oct 2024, 13:49Video is a bit tricky, best if you just load the same area in the same game and with the same angle, but it's very difficult to replicate, since you may not own the games I have, the area is in a very specific spot, etc.
Here are the jxrs
https://drive.google.com/file/d/1u0sRFL ... sp=sharing
https://drive.google.com/file/d/1g77t9- ... sp=sharing
And here are the photos, you can guess which is which by the name
https://drive.google.com/drive/folders/ ... sp=sharing
That's how my PG27 displays these images with 6500K HDR preset.
On the first one stone wall on the left side has purplish hue, wooden chairs on the right are not wooden color, but rather smeared reddish/brownish, stone wall on the right is also affected. It's not that apparent on the photo, I tried several times, it's easier to see with your eyes.
The second one is very noticable. See how the stone floor near the door is purple and smeared, wooden pillar also has this smearing. And the door itself btw. This photo exaggerates what I see, but can serve as a good example. That's the best my Xperia 1 VI can do, I don't have a proper camera.
The thing is I don't know how these exact scenes look on another woled monitors or even on LG 27GR95QE, which has the same panel. Is it inherent to this panel or it's just asus's engineers fault?
Just to reiterate, open the jxrs in standard windows image viewer, make a photo of the screen with hdr off and the on.
- RealNC
Here are the photos. I used the Special K image viewer (SKIV.exe) which has HDR support. Note that the color controls are locked out in HDR mode in this monitor. There is no way to switch from 6500K to anything else. It's all grayed out and inaccessible:Shifroval wrote: ↑05 Oct 2024, 06:44Here are the jxrs
And here with HDR turned off. I raised the brightness to 80% to make light output be as close as possible to HDR:
Shifroval
SKIV produced the same result as image viewer for me, but I could not be sure you have it or even know about it. Jxrs were taken by Special K btw. HDR ingame looks the same as captured image for me, always.
Interesting, I don't see any purplish hue or smearing on your photos. Do you see it yourself? Does it look like my photos to you? That's the main question.
