Software BFI on high refresh rate monitor
i_apocalypseon
Post by i_apocalypseon » 13 Oct 2024, 13:15
WIll something like desktop bfi or retroarch's inbuilt bfi work on a monitor that doesnt have bfi. But has, say, a 240 hz max refreshrate? What are the hitches? Is it better the higher the max refresh rate?
Re: Software BFI on high refresh rate monitor
Post by RealNC » 13 Oct 2024, 16:53
It will work. It's better at high refresh rates in the sense that you can choose how many black frames there are. 120Hz 60FPS for example only allows one choise: 1 content frame, 1 black frame. At 240Hz, you can choose how many black frames there should be.
Drawbacks are image retention issues with LCD panels. I don't think OLED panels suffer from this, but I'm not sure. Another drawback is severe flicker when frame pacing is not maintained. If there's a frame time spike, you will see a flicker that can be very annoying.
i_apocalypseon
Post by i_apocalypseon » 14 Oct 2024, 07:19
I tried retroarch bfi on my 60 hz sony lcd. And it flickers a lot. Is this the game not being able to maintain a locked 60? Frame pacing issues?
Post by RealNC » 14 Oct 2024, 14:17
i_apocalypseon wrote:
14 Oct 2024, 07:19
60Hz BFI flickers a lot already. With frame pacing issues, it flickers much worse because the flicker becomes uneven.
masterotaku
Post by masterotaku » 15 Oct 2024, 04:17
14 Oct 2024, 07:19
If the display is working at 60Hz and you enable BFI in RetroArch, you're getting 30Hz flickering and not 60Hz. If I remember correctly.
Monitor: Asus PG278QR
Post by RealNC » 15 Oct 2024, 09:10
masterotaku wrote:
15 Oct 2024, 04:17
Oh, oops. I missed that. Yeah, you can't expect BFI to be usable on a 60Hz display. To get 60Hz BFI, you need 120Hz.
i_apocalypseon
Post by i_apocalypseon » 15 Oct 2024, 13:34
Yep your right master rotaku. I have something called led motion mode on my tv. which is supposed to be like bfi. It is immune to ufo tests.. no optical illusions. I guess its still bfi at 60 hz tho
