Presentation Model Optimization / Makes any game smoother
Hyote
Re: Presentation Model Optimization / Makes any game smoother
Post by Hyote » 29 Oct 2024, 01:51
ahead wrote:
28 Oct 2024, 21:46
Syykfk wrote:
28 Oct 2024, 12:21
In addition, I am using win10, so what is the best suggestion for me in the optimization you mentioned? Thank you very much for your answer.
Upgrade to Windows 11 (c) Sincerely, Captain Obvious.
Yes, he needs News and Feeds constantly running in the background along with the latest eco-recommendations about lowering the refresh rate to conserve power. Windows 11 is trash and all the new Windows 10 versions are also straight downgrades from the older builds.
qvik18
Post by qvik18 » 29 Oct 2024, 10:23
reach0 wrote:
28 Oct 2024, 06:57
Don't use fse if you are on windows 11 if you are just turn on mpo and enable optimizations
Please can you elaborate a bit?I use windows 11
bwainzz
Post by bwainzz » 30 Oct 2024, 07:32
my insane ghosting with 360hz/500+ fps
along with that, everything we already know, floating mouse, desync etc.
ps: offline with bots, in the game it's even worse
alienware aw2523hf
reach0
Post by reach0 » 30 Oct 2024, 10:47
Syykfk wrote:
28 Oct 2024, 12:21
reach0 wrote:
28 Oct 2024, 06:57
I don't understand what you mean.
Do you mean, if you are using win11, then change Flags to 211 in the registry when opening mpo?
Don't think it's applicable for win 10 but for win11 I meant that you musn't do the old trick of disabling full screen optimizations and disabling mpo and instead deleting the flags folder for that game and it will reset the disabling optimizations trick and return it back to default which is fso + mpo which should be best.
You can also check your present mode with present mon and if it says hardware composed flip or hardware composed independent flip it should be correct.
InputLagger
Post by InputLagger » 03 Nov 2024, 19:07
bwainzz wrote:
30 Oct 2024, 07:32
alienware aw2523hf
Same for new, freshly created steam account?
Post by Slender » 04 Nov 2024, 05:08
Hyote wrote:
29 Oct 2024, 01:51
ahead wrote:
28 Oct 2024, 21:46
Syykfk wrote:
28 Oct 2024, 12:21
that right a little.
1803 latest good windows with old like win7 timer.
All_AImCSGO
Post by All_AImCSGO » 12 Nov 2024, 00:42
bwainzz wrote:
30 Oct 2024, 07:32
alienware aw2523hf
After months of procastinating I turned off high percision event timer and it fixed that issuie instantly. Just make sure you do it right.
bleya99
Post by bleya99 » 12 Nov 2024, 11:08
All_AImCSGO wrote:
12 Nov 2024, 00:42
bwainzz wrote:
30 Oct 2024, 07:32
alienware aw2523hf
Alright, I'll bite. What is your version of "correctly" doing timer settings?
