Online double conversion UPS then power on PC
Ogmax
Re: Online double conversion UPS then power on PC
Post by Ogmax » 01 Nov 2024, 09:59
widow13 wrote: ↑
30 Oct 2024, 14:05
skkiNN wrote: ↑
30 Oct 2024, 13:28
widow13 wrote: ↑
21 Sep 2024, 02:37
Patrykelele wrote: ↑
20 Sep 2024, 22:10
Do you have grounding?
I do.
still good man? or came back the lag and stuff?
I'm fine yes.
What ups have you got
widow13
Post by widow13 » 03 Nov 2024, 08:23
Ogmax wrote: ↑
01 Nov 2024, 09:59
widow13 wrote: ↑
30 Oct 2024, 14:05
skkiNN wrote: ↑
30 Oct 2024, 13:28
widow13 wrote: ↑
21 Sep 2024, 02:37
I do.
I'm fine yes.
I have the Powerwalker VFI 1000 TG UPS On-Line 1000VA 900W
spkii
Post by spkii » 08 Nov 2024, 12:41
widow13 wrote: ↑
03 Nov 2024, 08:23
Ogmax wrote: ↑
01 Nov 2024, 09:59
widow13 wrote: ↑
30 Oct 2024, 14:05
skkiNN wrote: ↑
30 Oct 2024, 13:28
I'm fine yes.
Do you have Computer, Display and Router connected to UPS? or Only Computer?
widow13
Post by widow13 » 08 Nov 2024, 14:48
spkii wrote: ↑
08 Nov 2024, 12:41
widow13 wrote: ↑
03 Nov 2024, 08:23
Ogmax wrote: ↑
01 Nov 2024, 09:59
widow13 wrote: ↑
30 Oct 2024, 14:05
I'm fine yes.
PC,Monitor and my routers.
Post by Slender » 08 Nov 2024, 21:55
widow13 wrote: ↑
08 Nov 2024, 14:48
input Max THDi ≀5%
THDv ≀2% @ 100% linear load, ≀5% @ 100% non-linear load
skkiNN
Post by skkiNN » 10 Nov 2024, 18:12
widow13 wrote: ↑
08 Nov 2024, 14:48
spkii wrote: ↑
08 Nov 2024, 12:41
widow13 wrote: ↑
03 Nov 2024, 08:23
Ogmax wrote: ↑
01 Nov 2024, 09:59
Bro, i think gona give a try taking same USP as urs and see if it helps.. But i have a problem, my router is far away from my PC and monitor so i think i could plug only my PC and monitor, but not my router.... Did u try all your sistem without attaching the router? could u do a test maybe? :(
widow13
Post by widow13 » 11 Nov 2024, 05:44
skkiNN wrote: ↑
10 Nov 2024, 18:12
widow13 wrote: ↑
08 Nov 2024, 14:48
spkii wrote: ↑
08 Nov 2024, 12:41
widow13 wrote: ↑
03 Nov 2024, 08:23
You'll be fine if it works, it doesn't matter. I plug my router just to be safe if the electricity goes down or something.
I used an extension to plug my router, you can use 1 if you want to.
skkiNN
Post by skkiNN » 11 Nov 2024, 05:58
widow13 wrote: ↑
11 Nov 2024, 05:44
skkiNN wrote: ↑
10 Nov 2024, 18:12
widow13 wrote: ↑
08 Nov 2024, 14:48
spkii wrote: ↑
08 Nov 2024, 12:41
Ye mate i was looking for an extension from amazon but didnt find anything, could u link me a product brodi?
spkii
Post by spkii » 11 Nov 2024, 06:22
widow13 wrote: ↑
03 Nov 2024, 08:23
[quote=Ogmax post_id=109542 time=<a href="tel:1730473188">1730473188</a> user_id=15781]
[quote=widow13 post_id=109520 time=<a href="tel:1730315131">1730315131</a> user_id=16271]
[quote=skkiNN post_id=109518 time=<a href="tel:1730312893">1730312893</a> user_id=10594]
[quote=widow13 post_id=108330 time=<a href="tel:1726904221">1726904221</a> user_id=16271]
I do.
[/quote]
I'm fine yes.
[/quote]
[/quote]
[/quote]
Do you have Amazon link to buy it and try? Thanks
widow13
Post by widow13 » 11 Nov 2024, 08:46
skkiNN wrote: ↑
11 Nov 2024, 05:58
widow13 wrote: ↑
11 Nov 2024, 05:44
skkiNN wrote: ↑
10 Nov 2024, 18:12
widow13 wrote: ↑
08 Nov 2024, 14:48
Literally any can work, I use one that looks like this. You gonna need an extra converter.
