This is the first I've heard of my Windows version being the problem. Would you mind elaborating? I keep everything updated. Is there a way to revert/update the build? What about 2009 is the problem?Hyote wrote: ↑26 Nov 2024, 04:58Jesus, those numbers. Get off version 2009, I don't know why so many people are stuck on that horrible half baked build. It doesn't have the newest features but in turn it has a lot of bugs and probably the worst performance ever.ticoex wrote: ↑25 Nov 2024, 15:54I've included the stats page too. I didnt include all drivers, just those with a DPC count and execution. Similarly, i did the top of the Processes tab. I did try a DDU reinstall of VGA driver before but ill try again with the file you listedwidow13 wrote: ↑25 Nov 2024, 15:21
Can u send the drivers,processes tab aswell ?
Also, try this driver to make sure it's not the driver, I don't have issues with this one.
Use DDU to get rid of the previous first.
https://www.mediafire.com/file/82b56ena ... 4.exe/file
Persistent, system-wide microstutter/jitter. Hard to diagnose
ticoex
Re: Persistent, system-wide microstutter/jitter. Hard to diagnose
ticoex
Gave that driver a try. No change in behaviorwidow13 wrote: ↑25 Nov 2024, 15:21
widow13
Hm interesting, are you really in version 2009 or is it a bug with the os ?ticoex wrote: ↑26 Nov 2024, 16:11Gave that driver a try. No change in behaviorwidow13 wrote: ↑25 Nov 2024, 15:21
Give it a check in windows specifications. Should look like this.
I'd re-install a fresh copy of windows and see if the PC behaves the same.
Hyote
Yeah I'd almost put money on the version being the culprit. Even more so if it was updated from a previous build. There are ways to update this but you definitely need a fresh install. A lot of problems with 1903-2009 ranging from bugs to insanely high latency at times.ticoex wrote: ↑26 Nov 2024, 11:37This is the first I've heard of my Windows version being the problem. Would you mind elaborating? I keep everything updated. Is there a way to revert/update the build? What about 2009 is the problem?Hyote wrote: ↑26 Nov 2024, 04:58Jesus, those numbers. Get off version 2009, I don't know why so many people are stuck on that horrible half baked build. It doesn't have the newest features but in turn it has a lot of bugs and probably the worst performance ever.ticoex wrote: ↑25 Nov 2024, 15:54I've included the stats page too. I didnt include all drivers, just those with a DPC count and execution. Similarly, i did the top of the Processes tab. I did try a DDU reinstall of VGA driver before but ill try again with the file you listedwidow13 wrote: ↑25 Nov 2024, 15:21
I'd suggest physically cleaning your pc, reseating the components, saving your BIOS settings and loading them after a CMOS reset before doing this however. Honestly those LatencyMon results look like the PC equivalent of a cancer patient.
If you don't wanna a fresh Windows install (I hate that too), try a full driver reinstall.
Sometimes I had to do full uninstall first, zero driver traces.
Reboot into what is essentially generic VGA/SVGA/XGA/etc adaptor mode.
Then reinstall driver.
Do not preserve NVCP settings, some hidden eastereggs can be bad.
Factory reset to new-system GPU settings FTW. You'll have to re-optimize from there.
Failing that, yeah, do the thing that you're balking at doing. (Hello Windows 11 ISO on a USB stick).
ticoex
Looks about the same
- OS version.png (18.17 KiB) Viewed 1870 times
widow13
ticoex
I've tried all this! I reseated everything i could think to, checked connections, and even blew away any dust. I have done multiple CMOS resets. Its driving me a little crazy tbh. Ill give those steps another go to morrow and see what happens.Hyote wrote: ↑26 Nov 2024, 17:00
ticoex
Ok, I can begin doing this. Do you have any guidance on uninstalling all drivers and reinstalling? I've tried before but didnt get confirmation the drivers were fully installed. Is there a way to check? Is it just as simple as booting into safe mode and uninstalling in device manger, disconnecting from internet and reinstalling driver after reboot?Chief Blur Buster wrote: ↑26 Nov 2024, 17:09If you don't wanna a fresh Windows install (I hate that too), try a full driver reinstall.
I have reinstalled windows recently. In my previous message I found my os version and it showed when I last tried fixing this issue (2 years ago)
widow13
Do urself a favor and do a fresh install.ticoex wrote: ↑26 Nov 2024, 18:32Ok, I can begin doing this. Do you have any guidance on uninstalling all drivers and reinstalling? I've tried before but didnt get confirmation the drivers were fully installed. Is there a way to check? Is it just as simple as booting into safe mode and uninstalling in device manger, disconnecting from internet and reinstalling driver after reboot?Chief Blur Buster wrote: ↑26 Nov 2024, 17:09If you don't wanna a fresh Windows install (I hate that too), try a full driver reinstall.
Last time you did was 2 years ago, that's a long time.
