Optimal G-Sync Compatible settings? Help please
mocha__
Post by mocha__ » 07 Dec 2024, 19:50
I have a 144hz Asus mg248q monitor that is Gsync Compatible (gsync only shows up in NVCP if I enable 'Adaptive Sync' in my monitor settings). Ive looked at the offical Gsync setup links and others setups online but I want to know from the professionals on here who know more about the difference gsync technologies so I can get the best setup.
In Nvidia Profile Inspector, I can set my Vsync to Adaptive instead of On or Fast, but which is the optimal settings for my specific Gsync compatible monitor? And should I still use Ultra LLM with a 138-137 fps cap in rtss?
Would appreciate anyone who can take the time to comment and clarify some things I mentioned (like Adaptive vsync with my sort of gsync compatible monitor). Id like to understand more in depth because theres so many gsyncs and Im not sure if this is a one size fits all situation, thanks
Re: Optimal G-Sync Compatible settings? Help please
Post by RealNC » 08 Dec 2024, 01:54
mocha__ wrote:
07 Dec 2024, 19:50
Adaptive sync in Nvidia means something else than adaptive sync in the monitor OSD. Don't use that with g-sync. Just use normal vsync. Ultra low latency is fine. If the game has Reflex, use that instead.
In general, just read the articles on it:
https://blurbusters.com/gsync/gsync101- ... -settings/
