dedicated internet line against the mysterie desync input lag
[email protected]
Post by [email protected] » 11 Dec 2024, 05:07
Hello guys,
have someone tested a dedicated internet line against the mysterie desync input lag?
Re: dedicated line against the mysterie desync input lag
Post by Slender » 11 Dec 2024, 06:50
[email protected] wrote:
11 Dec 2024, 05:07
Hello guys,
have someone tested a dedicated line against the mysterie desync input lag?
same question! I saw someone do this and it didn't help. But you can’t rely on someone else’s experience, you just need to take it and do it. Recently I knocked out the plugs on my line, boom, the heaviness in my body went away, the wiring stopped emitting background noise. Perhaps the PC is responding to wiring behind the wall. Try moving the PC to the center of the room, use wt3121 to see if there is interference from the PC, if it shows 0 v/m, then nothing externally affects your PC.
if you mean network dedicated line - no.
There is Christopher who did this, it didn’t help him, but the corsair at 1200w helped.
Mugabi
Re: dedicated internet line against the mysterie desync input lag
Post by Mugabi » 11 Dec 2024, 20:55
Please don't, I know 2 from discord who spent tremendous money on it without any improvement. One helped him for few days apparently then lag came again.
Unreazz
Post by Unreazz » 15 Dec 2024, 15:32
oldschool7 did on 2 places with no avail. the only benefit on a dedicated line is, that you get your own linecard on the DSLAM and this does basicaly nothing. you get also a better support service
joseph_from_pilsen
Post by joseph_from_pilsen » 21 Dec 2024, 23:02
Exactly, there is nothing such like a "dedicated" internet line. It ends in the same switch from provider to global network. Which is mostly the source of most of the lag and issues /hi, telia sonera/.
