It won't be perfect it may even suck a little but it will be better than the ELMB Sync garbage that ASUS puts out.
Poor brightness and lack of VRR is the main turn off for people when they hear about strobing.
I would buy a Zowie monitor but I refuse to use this TN garbage
The next blur buster monitor should support VRR with Strobing and 325 Nits brightness
Re: The next blur buster monitor should support VRR with Strobing and 325 Nits brightness
Do I think it's a reasonable decision? Maybe I would also prioritize a monitor like that? Do you have any reviews or reliable sources of information to compare monitors for others facing similar choices? (like me, for example
