gpu scaling vs Display scaling
Tiberiusmoon
Re: gpu scaling vs Display scaling
Post by Tiberiusmoon » 27 Apr 2023, 15:13
TN_fun wrote: ↑
27 Apr 2023, 14:09
What resolution are you using in the game?
The guy above is talking about a native resolution, full hd
For him it is better to use (he said so) display scaling, full screen.
1080p native.
As I said, GPU scaling may contribute to a GPU bound scenario which adds latency to give a different "feel" of input latency.
Coldplayer
Post by Coldplayer » 22 Jun 2023, 23:46
Anyone know with a 2546k if the display scaler will be better than a 3080? Also do I use no scaling or full screen?
daviddave1
Post by daviddave1 » 23 Jun 2023, 18:26
Coldplayer wrote: ↑
22 Jun 2023, 23:46
from my understanding displayscaler gives less lag.,
| Now: XG27AQNGV
Post by jorimt » 23 Jun 2023, 21:15
owslahd97 wrote: ↑
10 Jan 2023, 07:24
According to my own understanding, the games I play and my desktop resolution are both 1920X1080, so Can you show that no scaling is necessarily the best option no matter what GPU/display scaling I use?
There should be no latency difference between NVCP scaling modes at native resolution, since neither the monitor scaler nor GPU will be used to "scale" said native resolution.
I just tested my PG27AQN (1440p 360Hz native G-SYNC) with an LDAT (top left corner of screen - where the scanout starts - using its test app, which flashes from black to white), and there's virtually no measurable difference between the NVCP scaling modes for me (40 samples per scenario):
Display, No scaling (Override the scaling mode set by games and programs)
avg - 20.5ms
min - 15.9ms
max - 25.3ms
GPU, No scaling (Override the scaling mode set by games and programs)
avg - 20.4ms
min - 16.2ms
max - 25.3ms
It was the same whether I had the Aspect ratio or Full screen scaling options applied for either the Display or GPU mode.
There should only be latency differences between Display and GPU scaling when you're monitor is set to a lower non-native resolution, the differences of which can depend on your particular monitor model's scaler (in Display scaling mode) and/or your GPU (in GPU scaling mode).
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
Bloedboer
Post by Bloedboer » 29 Jun 2023, 02:15
Coldplayer wrote: ↑
22 Jun 2023, 23:46
I don’t think so, the scaler is quite bad. With cru you can get it nicer looking but still not as smooth as with gpu scaling. If you ever find out how to get it better pls let me know!
UNATCO
Post by UNATCO » 29 Jul 2023, 10:04
Tiberiusmoon wrote: ↑
27 Apr 2023, 15:13
TN_fun wrote: ↑
27 Apr 2023, 14:09
1080p native.
By this logic, would you agree that if Im using a 3080, and a 4k Neo G7 165hz, Display scaling/no-scaling/override would make sense over GPU scaling/no-scaling/override?
Weissrolf
Post by Weissrolf » 30 Jul 2023, 13:00
Display scaling used to add at least 1 frame of processing time, so a 60 Hz display would display the same image 16.66 ms later. No idea how more modern display handle this.
Sptz
Post by Sptz » 11 Oct 2023, 10:12
UNATCO wrote: ↑
29 Jul 2023, 10:04
27 Apr 2023, 15:13
TN_fun wrote: ↑
27 Apr 2023, 14:09
1080p native.
I'm interested in knowing this as well as a prospective Neo G7 buyer.
I'm currently on a G34WQC (ultrawide) on a 4090. Settings are No Scaling - Display. This is because the only game I'm going to play at a lower resolution is CS2 and for that I don't want it to scale up but to just display the resolution as is, centered.
Now, I can confirm Display Scaling is working properly, if I go to the OSD it shows the resolution I'm playing at which is 2560 x 1440. It both looks and feels absolutely perfect, no input lag whatsoever (perceived). I'm guessing because there isn't any actual scaling going on am I correct? Since it's displaying the resolution "as is" without scaling it to fill the screen or anything like that.
Just want to make sure if this is the correct idea?
Images illustrating what I mean:
OSD showing correct resolution
NVCP Settings (No idea why the preview shows as if scaling would be occurring?)
mojosan
Post by mojosan » 27 Dec 2024, 22:41
What i still cant understand is why ticking *No scaling* while playing 1080p Valorant on a 1080p display no matter the scaling method - stills feels weird. This is no placebo. Its so obvious that ppl can just recreate and test it on the fly..
pirinfarina
Post by pirinfarina » 03 Jan 2025, 18:56
mojosan wrote: ↑
27 Dec 2024, 22:41
It's definitely not placebo. I believe this happens because when selecting it, the setting 'Perform scaling on:' is still appearing and can be changed, what makes no sense. I think It could be fixed by removing 'perform scaling on' and leave 'disable scaling mode set by games and programs' checked, just like with integer scaling.
