1080p native.
As I said, GPU scaling may contribute to a GPU bound scenario which adds latency to give a different "feel" of input latency.
1080p native.
from my understanding displayscaler gives less lag.,Coldplayer wrote: ↑22 Jun 2023, 23:46Anyone know with a 2546k if the display scaler will be better than a 3080? Also do I use no scaling or full screen?
There should be no latency difference between NVCP scaling modes at native resolution, since neither the monitor scaler nor GPU will be used to "scale" said native resolution.
I don’t think so, the scaler is quite bad. With cru you can get it nicer looking but still not as smooth as with gpu scaling. If you ever find out how to get it better pls let me know!Coldplayer wrote: ↑22 Jun 2023, 23:46Anyone know with a 2546k if the display scaler will be better than a 3080? Also do I use no scaling or full screen?
By this logic, would you agree that if Im using a 3080, and a 4k Neo G7 165hz, Display scaling/no-scaling/override would make sense over GPU scaling/no-scaling/override?Tiberiusmoon wrote: ↑27 Apr 2023, 15:131080p native.
I'm interested in knowing this as well as a prospective Neo G7 buyer.UNATCO wrote: ↑29 Jul 2023, 10:04By this logic, would you agree that if Im using a 3080, and a 4k Neo G7 165hz, Display scaling/no-scaling/override would make sense over GPU scaling/no-scaling/override?Tiberiusmoon wrote: ↑27 Apr 2023, 15:131080p native.
It's definitely not placebo. I believe this happens because when selecting it, the setting 'Perform scaling on:' is still appearing and can be changed, what makes no sense. I think It could be fixed by removing 'perform scaling on' and leave 'disable scaling mode set by games and programs' checked, just like with integer scaling.
