Desync in all games with new cat 8
Sari
Re: Desync in all games with new cat 8
Post by Sari » 19 Jan 2025, 16:42
ZINZIRIO wrote:
15 Jan 2024, 19:57
Yes exactly, I will continue using the old one, the truth is that I am a little surprised that two network cables affect the performance of a game so much.
hey bro, is the symptoms u had include, (slow mouse) feels folaty or on ice, (Desync) enemies see you before you see them like they peek kill you and then you see them after you already died, (bad hitreg) the bullets never register no matter how hard you try to aim it barely hits the enemy and it feels like the bullets are flying around and not straight. ?
also can you send me a link of the old ethernet cable (the good one)
Post by Slender » 19 Jan 2025, 18:50
reason is grounding.
cat8 is sftp?
if that black sftp cable that is it.
you connect pc ground and lan provider (or router) ground. You can remove ground contact from cable and and you won't see any difference.
Cat8 sftp cause + 8% THD for my setup (i think bad router psu cause that).
better variant use sftp to router. From router to pc use standard unground lan cat5e.
akylen
Post by akylen » 20 Jan 2025, 17:26
As i see on the description , both are "S/FTP" no ?
Cable Construction: S/FTP (Shielded Foiled Twisted Pair).
6. Construction: S/FTP (Shielded Foiled Twisted Pair)
ahead
Post by ahead » 20 Jan 2025, 23:48
Under 100m, the same speed connection delivers identical latency, whether using Cat 8, Cat 5, or fiber optic cables.
[email protected]
Post by [email protected] » 21 Jan 2025, 07:32
akylen wrote:
20 Jan 2025, 17:26
Yes, both are the same. The only difference is the color.
Maybe a production failure on the white one.
ProGrueso
Post by ProGrueso » 08 Aug 2025, 02:47
ZINZIRIO wrote:
13 Jan 2024, 20:41
I bought some white CAT 8 network cables
Can you specify what gauge this Cat 8 Ethernet cable have? This info is printed along the cable, look for a number like: 28 AWG. Best Ethernet cables to date are the 22 AWG. Lower number (Thicker, more copper inside, hard to bend)=Fast cable. Higher number= congested cable (Thinner, less copper inside, easy to bend). Compare it to your old cable. That could be the reason it works better.
donger
Post by donger » 10 Aug 2025, 17:39
don't use chinese knockoff noname shit and you will not have problems in your life, standards were made for a reason
scummy chinks are using alluminum insted of copper and this leads to all kinds of problems
amorou
Post by amorou » 11 Aug 2025, 07:34
Shielded ethernet cable adds massive mouse lag in my home
Post by Slender » 11 Aug 2025, 08:45
amorou wrote:
11 Aug 2025, 07:34
it be if your router is not grounded.
amorou
Post by amorou » 11 Aug 2025, 09:23
Slender wrote:
11 Aug 2025, 08:45
amorou wrote:
11 Aug 2025, 07:34
Never saw a grounded router yet
