this fixed my lag!!!
badmadkarma
Post by badmadkarma » 11 Feb 2025, 06:46
edit: it was a psu problem. underload load voltage is dropping below recommeneded.u can check it using hwinfo.
everything else default execpt the ones listed below
bios: (through scewin )
PECI Access Method : acpi --- default was input i/o.chatgpt says default is better option but was not for me.
Enable ACPI Auto Configuration : enabled ---- default was disable
turbo power limit:enable (can be directly accessed for me)
now manually set all package power limit1&2 , platform power limit1&2 . i have set everthing very conservatively . ask chatgpt for the formulae with your system specifications. always be on safe side.
xmp :enabled
c states: disabled ----acpi(windows) will control the power saving instead of bios firmwire. general temp is 2-3 degree higher
windows 10 :
device manager-> system devices->uninstall microsoft acpi compliant system -> restart
system will resinstall it . when you uninstall , mouse and keyboard will stop working so you have to force restart.all irqpolicy settings will change to default system . i have to do it every days, otherwise lag will slowly creep up.
cmd bcdedit :
bcdedit /set tscsyncpolicy Enhanced
bcdedit /set useplatformclock No
bcdedit /set useplatformtick Yes
bcdedit /set disabledynamictick Yes
i have made a bat file and created a task to always run at start. did it so that programs may not accidently change the settings.
external pcie usb card (asmedia driver):
i use external pcie usb card (asmedia driver) to connect my headphone . mouse and keyboard is connected directly to motherboard.
if i connect headphone directly ,after a days audio will start to lag and general lag will return .
NB: not recomended for laptop users. change at your own discretion. warning -under my previous post someone commented they got bsod and had to reinstall windows.
themagic
Re: this fixed my lag!!!
Post by themagic » 11 Feb 2025, 08:17
Congrats !
You find real Fix !
ChatGPT already tell me this in 2015 but i want to know if someone gonna find this fix.
Hyote
Post by Hyote » 11 Feb 2025, 11:49
themagic wrote: ↑
11 Feb 2025, 08:17
Congrats !
You find real Fix !
That's nice.
jassine
Post by jassine » 11 Feb 2025, 16:33
themagic wrote: ↑
11 Feb 2025, 08:17
Congrats !
You find real Fix !
did it work for you ?
themagic
Post by themagic » 11 Feb 2025, 16:40
jassine wrote: ↑
11 Feb 2025, 16:33
themagic wrote: ↑
11 Feb 2025, 08:17
Congrats !
You find real Fix !
No. This clearly Joke from me...
But you can go and try and everyone who want.
Good Luck.
I am already done long ago with BIOS and Bcdedit tweaks and everything tried many times on Repeat...and this clearly dont the problem for People like me and not the Core Problem and Culprit which i experience here.
Hyote
Post by Hyote » 12 Feb 2025, 05:07
The things you did are the usual temporary fixes like underclocking, using settings that actually increase latency, resetting, reinstalling, the issue still remains. I forgot to add this previously.
