Would rlly appreciate some help with getting the right flip model on my game
awuhdlaui
Hey guys, would just like some help with making my game run with Hardware composed : independent flip instead of hardware : independent flip as I have read that it's better. Always searching for the best mouse feel for games like cs2 and valorant and hope this will help a bit more with that.
- Screenshot 2025-02-26 130740.png (7.16 KiB) Viewed 7995 times
- Panychkaaa
Re: Would rlly appreciate some help with getting the right flip model on my game
HKEY_CURRENT_USER\System\GameConfigStore\Children\ -> Search (VALORANT-Win64-Shipping.exe) -> Flags -> 211
1000WATT
You want?
awuhdlaui
Hey, I tried this on cs2 and it made my game run in Hardware : legacy flip. I remember watching a video about the reg edit, pretty sure it just disables fullscreen optmizations.Panychkaaa wrote: ↑26 Feb 2025, 10:25HKEY_CURRENT_USER\System\GameConfigStore\Children\ -> Search (VALORANT-Win64-Shipping.exe) -> Flags -> 211
In the attachment it says to achieve hardware composed : independent flip that i need directflip optimizations. ahh just realised that it says i need multi plane overlay enabled but I thought i did. pretty sure i do have it enabled unless i somehow disabled it in a tweak? Would you happen to know a way to force MPO?
awuhdlaui
yeah. Just looked around and seen that its apparently better, you should be able to see the image of the different flip models in my reply to the other guy above. Its saying that i dont have mpo enabled but it doesnt make sense, because im pretty sure I do. unless its outdated.
- RealNC
"Hardware composed: independent flip" is what I get with MPOs enabled. "Hardware: independent flip" is with MPOs disabled (due to HDR or DSR.)
That's on Windows 10 though.
awuhdlaui
do you think that using scaling, like stretching 4:3 in cs or valorant would effect it? Is there a way to tell if mpo's are enabled or not?
- RealNC
I use SKIF (SpecialK's GUI frontend) to check it:
- kyube
Reminder for anyone attempting to use SK:
Special K does not work in games which use a kernel-level anti-cheat and may trigger a ban, as it injects into the process itself.
The alternative is, use PresentMon to find out the flip mode of a game.
JimCarry
i dont have these keys i delete them long time ago,any other way? i have mpo disabled and in gameconfigstore everything is on 0.Panychkaaa wrote: ↑26 Feb 2025, 10:25HKEY_CURRENT_USER\System\GameConfigStore\Children\ -> Search (VALORANT-Win64-Shipping.exe) -> Flags -> 211
