Possible Desync & Input Lag Fix Utilizing G-Sync
serenamannesh
Post by serenamannesh » 02 Mar 2025, 00:38
Look up 'Valorant Desync Fix' on the "r/ValorantTechSupport" sub-reddit.
Did the tweak outlined by the author, and felt an immediate and almost complete relief from both input lag and desync for some odd reason.
I would like some insight as to why this is, and how to fully diminish the feeling of input lag/desync using g-sync as a baseline. I feel like I am on to something here.
-Takeda-
Re: Possible Desync & Input Lag Fix Utilizing G-Sync
Post by -Takeda- » 03 Mar 2025, 01:28
Can you keep us updated? I tried one of the fixes on here and it worked for a few hours until I had to go to work. When I came back it was all the same again. If you have this issue, you will always know if it feels different or not. All of the fixes i've tried are not permanent.
serenamannesh
Post by serenamannesh » 03 Mar 2025, 06:07
-Takeda- wrote: ↑
03 Mar 2025, 01:28
This fix definitely works, or it certainly nudges something at least. In my opinion it is very finicky, and inconsistent-but when it works you'll notice 100%. In the past I have dabbled with network adapter tweaks and while those have helped a ton they do not work past a certain point, you understand that seeing as how "tweaks work for a little while then cease being effective". But this one sticks through reboots, etc... I haven't tested graphics cards updates while doing this though.
