If you use surround monitors, and want to run then with LightBoost, you will want NVIDIA graphics driver 332.21:
https://forums.geforce.com/default/topi ... d-1-7-14-/
It reportedly fixes surround 1440p 120Hz with overclockable 120Hz monitors, as well as it should fix surround LightBoost.
Surround LightBoost fixed in Driver 332.21
- GitDat
Re: Surround LightBoost fixed in Driver 332.21
This driver didn't work for me. Using the emitter works but having 3D enabled in the Nvidia control panels kills my frame rates
Cougar Conquer 2 | MSI Meg Z390 Godlike | 9900K | NZXT Kraken X72 | 32GB TridentZ RGB 3600MHz | RTX 3090 FTW3 Ultra | Samsung 960 Pro NVMe M.2 SSD RAID-0 | Corsair AX860 | 3DMark Port Royal - 14204 | Windows 10 Pro 64-bit | Triple 32" Samsung CHG70 | Samsung CHG90 Super-Ultrawide Auxiliary
