So I deleted the ASUS ICC profile that I downloaded from their website and now I'm using AMD's Adrenalin color setting and it's indeed less saturated than before. I will check if the AMD driver settings are applied in HDR mode.Yes. I don't know if the AMD driver will automatically disable the clamp when switching to HDR though or whether you need to disable it manually.
Also note that if you installed the "monitor driver" and have the Asus ICC profile active in Windows Color Management for the monitor, you will get double-clamped in some cases. So check there to see if it installed a color profile.
Thanks, I did the same. I guess it does run on stand-by because I'm already at 27 cleanings.
I wouldn't worry about it. I just run pixel cleaning every 4 to 5 hours on average. I bound the right direction of the control stick of the monitor to the pixel cleaning function so I can quickly run it when I leave my desk.
In regards to SRGB, the best way to clamp the color settings would be at the hardware/monitor settings, correct? And then would it be at the driver level or Window's ACM (Auto Color Management)?
Is there anything in Windows 11 that can check the current SRGB accuracy? Thanks for your time.
