I upgraded from an AW2521H (G-sync module) to a 27GS93QE (basic freesync). On the old monitor, if I manually set a game/app to 'Fixed Refresh' in NVCP, it would behave nicely and simply not engage VRR when I tabbed into that game/app. On the new monitor, manually setting a program to 'Fixed Refresh' causes it to seemingly switch display mode every single time I alt-tab into or out of said program, causing a 2 second long black screen. This is true even of windowed programs like Photoshop (where disabling VRR is a must due to tons of stuttering and flickering that it causes).
Is there any way to fix this or is it an unavoidable downside of the G-sync module-less hellscape we now exist in?
Changed monitor, now disabling VRR on a per-app basis causes black screen
rubiconlexicon
- RealNC
Re: Changed monitor, now disabling VRR on a per-app basis causes black screen
I had something similar and the fix was to reset the global profile in the nvidia control panel (with the "Restore" button.)
The problem would reappear sometimes if I kept using NVCP to set some games to fixed refresh. If I instead use nvidia profile inspector, it doesn't happen:
viewtopic.php?f=5&t=10062&p=108432&p108432#p108432
If you don't have profile inspector, it's this:
https://github.com/Orbmu2k/nvidiaProfil ... r/releases
rubiconlexicon
Thanks. Resetting global profile in NVCP did not work but using NPI to disable Gsync instead of NVCP did work!RealNC wrote: ↑16 Mar 2025, 05:54I had something similar and the fix was to reset the global profile in the nvidia control panel (with the "Restore" button.)
- RealNC
Maybe you have to reset all customized profiles in NVCP, not sure. The problem also caused another issue for me, where after booting into Windows, after 5 seconds or so, the screen would blank out for half a second then come back. It did this exactly one time, every time after rebooting.rubiconlexicon wrote: ↑22 Mar 2025, 01:37Thanks. Resetting global profile in NVCP did not work but using NPI to disable Gsync instead of NVCP did work!
Just weird.
rubiconlexicon
I also get this exact issue... I'm starting to wonder if it's time for a clean Windows reinstall. These little issues aren't getting fixed even with a clean driver install.
- RealNC
DDU fixed it for me before I discovered it can be fixed by NVCP reset. However, I think the reset working might depend on whether g-sync support in enabled or disabled in the G-SYNC section of NVCP.rubiconlexicon wrote: ↑22 Mar 2025, 17:29I also get this exact issue... I'm starting to wonder if it's time for a clean Windows reinstall. These little issues aren't getting fixed even with a clean driver install.
saserlo
I'm still not sure, I'm getting this error.
TanishaGreen12
Right, a new monitor shouldn't introduce such headaches. Variable refresh rate woes, a modern curse indeed. I remember a similar situation, though slightly different, when dealing with resolution scaling on an older TV. Disabling specific features created unintended chaos with the signal. This sounds like a driver issue, potentially related to FreeSync implementation. I once had the most unusual experience trying to present a PowerPoint on an ancient projector, and every slight Adju Slope stment to the brightness caused the whole screen to flicker uncontrollably, forcing me to present without visuals.
