lan driver ( floaty mouse ,etc )
kyube
Re: lan driver ( floaty mouse ,etc )
Post by kyube » 27 Mar 2025, 14:46
ablemor wrote:
27 Mar 2025, 12:44
But then why is it that I've tried so many systems—Intel, AMD—and the mouse is still bad? And no one else has this problem, only me. I don't understand this. So, is the DPC causing the floaty mouse movement?
“Floaty mouse” is a vague term and extremely subjective. What one user finds “floaty” may be optimal for the other user.
You could be more perceptive than others in regards to this. You also could've done improper HW & SW choices historically and cloud your perception.
I cannot give you a concrete solution, unless you do the troubleshooting yourself and report back or you ask someone to do it for you.
LatencyMon is not a good way to troubleshoot DPC/ISR of your system, especially at idle doing nothing.
ASMedia PCIE add-in cards are cheap, you can consider those as a potential solution to this.
They're one of the better performing drivers in terms of DPC/ISR.
ablemor
Post by ablemor » 27 Mar 2025, 15:09
I have pcie usb card, and nothing happened-
kyube
Post by kyube » 27 Mar 2025, 15:20
ablemor wrote:
27 Mar 2025, 15:09
“pcie usb card” can mean anything.
Which DEV_ID in device manager? If it's a card with an ASMedia controller, have you installed the vendor specific driver?
Refer to the thread in my signature.
ablemor
Post by ablemor » 27 Mar 2025, 15:22
PCI\VEN_1106&DEV_3483&SUBSYS_34831106&REV_01
ablemor
Post by ablemor » 27 Mar 2025, 15:26
via usb 3.0
Randomguy007
Post by Randomguy007 » 27 Mar 2025, 16:04
kyube wrote:
27 Mar 2025, 14:46
ablemor wrote:
27 Mar 2025, 12:44
your absolutely right man, I see people conplaining about floaty mouse who were top 500 in owerwatch…. I would literally pay thousands of dollar to get his „floaty“ feeling. My floaty mouse actually limits me to really low ranks
ablemor
Post by ablemor » 27 Mar 2025, 16:45
And how would this solve the floaty mouse problem? What do you mean by optimized? I don’t understand any of this, I don’t know how it works. I’ve already tried countless USB ports, all of them are just as bad, the mouse feels floaty, I get headshotted instantly, I overaim, I’ve changed the motherboard, processor, switched from Intel to AMD, even changed my monitor. I have a 380Hz monitor, tons of FPS, and yet I still get killed.
Hyote
Post by Hyote » 27 Mar 2025, 16:57
If something goes bad periodically or randomly then it's most likely caused by something other than bqd hardware or software configurations. Again, I had my phone affected by this, PlayStation, TV, every electronic device you could control with your hands in some way.
Existing ideas aren't going to fix it alone, this needs to be thought through with care.
sulaemulae
Post by sulaemulae » 27 Mar 2025, 20:16
Have the same network card, try setting low priority to it on msi utility, you'll be surprised how mouse sens changes. Mouse/keyboard is just a part of input lag, you may have a perfect m&k but dogshit hitreg and motion clarity :).
