Look I never wanted to believe zd either but my pc is running perfectly fine so
Desync gone
texre
Re: Desync gone
That sucks. But I also never told you to do that either I’m just explaining what helped me , not every fix will be the same. Sorry.Randomguy007 wrote: ↑06 Apr 2025, 18:23Mannn i swapped out every hardware and everything was new and nothing helped..
texre
Randomguy007
Re: Desync gone
Have you swapped out the whole pc at once or each item 1 by 1
texre
Re: Desync gone
I changed everything 1by1 and I still had my problem. My problem didn’t go away until I changed everything at one time. New pc case new ram new motherboard new psu new gpu new m.2 new cooler everything new besides my peripherals. I still use the same mouse but I did end up changing my monitor and keyboard but that was already after Ik my build was good. My old build every single game was blurry. With my new build everything is crisp smooth and clear I can see everythingRandomguy007 wrote: ↑07 Apr 2025, 12:35Have you swapped out the whole pc at once or each item 1 by 1
texre
Re: Desync gone
Question for everyone? Are your games blurry ?
Randomguy007
Re: Desync gone
ty mate you give me hope. So you think that by seapping 1 by 1 it always got more „infected“texre wrote: ↑07 Apr 2025, 12:42I changed everything 1by1 and I still had my problem. My problem didn’t go away until I changed everything at one time. New pc case new ram new motherboard new psu new gpu new m.2 new cooler everything new besides my peripherals. I still use the same mouse but I did end up changing my monitor and keyboard but that was already after Ik my build was good. My old build every single game was blurry. With my new build everything is crisp smooth and clear I can see everythingRandomguy007 wrote: ↑07 Apr 2025, 12:35Have you swapped out the whole pc at once or each item 1 by 1
texre
Re: Desync gone
I believe so yes because I would always change parts out and it would feel great for some days to a week then come back.Randomguy007 wrote: ↑07 Apr 2025, 12:45ty mate you give me hope. So you think that by seapping 1 by 1 it always got more „infected“texre wrote: ↑07 Apr 2025, 12:42I changed everything 1by1 and I still had my problem. My problem didn’t go away until I changed everything at one time. New pc case new ram new motherboard new psu new gpu new m.2 new cooler everything new besides my peripherals. I still use the same mouse but I did end up changing my monitor and keyboard but that was already after Ik my build was good. My old build every single game was blurry. With my new build everything is crisp smooth and clear I can see everythingRandomguy007 wrote: ↑07 Apr 2025, 12:35Have you swapped out the whole pc at once or each item 1 by 1
It’s so crazy to me because tweaks actually work for my pc now and it’s not placebo. I’ve done some tweaks to the bios that was recommended to me by a tweaker and man I look crazy in games now
Kipperii
Re: Desync gone
what bios tweak?texre wrote: ↑07 Apr 2025, 12:55I believe so yes because I would always change parts out and it would feel great for some days to a week then come back.Randomguy007 wrote: ↑07 Apr 2025, 12:45ty mate you give me hope. So you think that by seapping 1 by 1 it always got more „infected“texre wrote: ↑07 Apr 2025, 12:42I changed everything 1by1 and I still had my problem. My problem didn’t go away until I changed everything at one time. New pc case new ram new motherboard new psu new gpu new m.2 new cooler everything new besides my peripherals. I still use the same mouse but I did end up changing my monitor and keyboard but that was already after Ik my build was good. My old build every single game was blurry. With my new build everything is crisp smooth and clear I can see everythingRandomguy007 wrote: ↑07 Apr 2025, 12:35Have you swapped out the whole pc at once or each item 1 by 1
