what usb ports are better?
JimCarry
Re: what usb ports are better?
Post by JimCarry » 20 Apr 2025, 03:38
yarusskiy228 wrote: ↑
19 Apr 2025, 16:26
JimCarry wrote: ↑
19 Apr 2025, 14:39
RealNC wrote: ↑
19 Apr 2025, 04:35
JimCarry wrote: ↑
18 Apr 2025, 20:02
on my mb when i asked chatgpt,it says that the blue ones are connected to the cpu
Blue indicates it's USB 3, not that it's connected to the CPU's controller:
ok so can you tell me on my mb wich are the ones to the cpu please?
I looked at your motherboard and it also seems to me that the USB from the CPU are the blue ports
maybe yeah,maybe no.
slava1337
Post by slava1337 » 25 Apr 2025, 05:21
RealNC wrote: ↑
18 Apr 2025, 10:14
10 or 11 if you want it on the CPU's USB controller, or one of the ports labeled "3" if you want it on the chipset's controller.
Does it matter? I have never seen a difference. But I'm on a 1000Hz mouse. Maybe with higher polling rate mice it makes a difference, I don't know.
But anyway, also take a look at this:
viewtopic.php?f=10&t=7618
always use usb 2.0 for mouse and keyboard for lower latency
is it true?
X3D MASTER RACE
slava1337
Post by slava1337 » 25 Apr 2025, 06:06
17 Apr 2025, 15:23
what usb ports are better to choose on msi pro b650 m-p? My mouse, keyboard and microphone have USB. and I don't know where it's better to insert them into my motherboard for less latency. please help me.
11 and 12 say "from cpu"
11 for mouse
12 for kb
X3D MASTER RACE
