Post
by JimProfit » 12 Jun 2025, 18:20
Yes, I have asked specifically about the QN90F and QN90C (in the faint hope that snatching a 2023 model would get me low-MPRT 120hz BFI).
The QN90F was updated to 60hz BFI only, but the reason I'm not sure they'd even bother checking the QN90C is because another commenter asked the team if they'd update the test it to the latest protocol and RTINGS flat out said no (no time to spare for that).
So, to sum it up, we already knew that the 8K QN900C, QN900D, and lastly the QN900F, as well as the higher-end 4K models QN95B/C/D were listed as 60hz-BFI-only, from the beginning.
We know the QN90D and QN90F were listed as 120hz BFI compatible and were updated to 60hz only upon me mentioning my problem, prompting them to re-test those two models.
That leaves the 120hz BFI status unknown on the following older models, which may never be re-tested by them: 8K QN900A/B + QN800A, and 4K QN90A/B/C as well as various low and mid range QN85 and QN80 models from years prior.
The phrasing used by the RTINGs rep was not perfectly clear on whether it was simply a mistake on their part (in which case we could reasonably assume that none of them strobed at 120hz to begin with) or if it is Samsung that intentionally nerfed their own products via firmware update for no reason.
Of course we know that any manufacturer can take a backward step and discontinue something good like LG did with rolling-scan BFI.
What I would never expect LG to do however, is to remove the option from my 2020/2021 models via firmware update.
Right now I'm thinking of putting the QN90D in the GX"s old spot and use it for 60fps-or-under games that need motion clarity above anything else.
I lose the GX's perfect blacks and absence of crosstalk, but I get higher overall motion clarity and a much better brightness level (again perhaps suitable for HDR400, which no other Samsung seem to be able to do).
And I can also do non-strobed HDR up to 2000nits at 144hz (including low-lag interpolation) when peak brightness is more important, until I pull the trigger on a newer OLED model that'll do that task a lot better.
And if my games can reach 100/120fps, I think I will stay mostly on the G1 for now (same strobing modes' performance as the GX for 100/120hz, and a bit brighter across the board). Even though 120hz BFI on the G1/GX is technically blurrier than 60hz backlight strobing on the QN90D.
But at least I get perfect contrast, perfect pixel response time, no crosstalk, slightly less lag,..
Both TVs are arranged in adjacent rooms but connected to the same PC, and with a high performance strobing monitor on the side (ULMB at 120/144/240/360hz, sub-1ms MPRT capable), the idea is to always have the best of both worlds.
But gee, even doing my homework as best as I can, I sure am not immune to disappointment.
OLED (HDR): LG OLED65G1 - LG OLED55GX
LCD (HDR): Samsung 65QN95D - Samsung 65QN90D - Asus PG27AQN - Panasonic 58EX780E
LCD (SDR): Asus PG27VQ - Asus PG278QR
PDP (SDR): Pioneer KRP500A
CRT (SDR): Sony FW900 - Sony D24E1WE (ooo) - Iiyama HM204DT - Mitsubishi 2070SB - Toshiba 2887DF
