Good news on solving the problem of input delay
Inputlagger91
Hello again from a guy from Russla. I won't write much, because it's already night, but I want to share the good news, recently I've been experimenting a lot with the settings of the Adrenaline application from amd and I think I did something and the game became better (cs2), it started to register better and the mouse is more, in short, it's playable, but the network filter started to make a lot of noise and I decided to change it. I bought a matihur (hifi) network filter today, but after hooking everything up to it, I caught a floating mouse again and so on, then I decided to leave only the monitor in it, and the computer in a separate outlet, reset the adrenaline settings, and set everything up again so that at least it was playable again. But later I decided to put the computer in the filter again and felt an improvement and this is not a placebo, even later I decided to take a risk again and reset all the settings and it didn't get worse, the main improvement in addition to a sharp mouse and more accurate aiming is controlled shooting with single bullets from such weapons as AK47 and M16, which has not happened since csgo. I will attach a photo of the filter. And I will try to keep you informed. I apologise for my English, I use a translator.
- IMG_8411.jpeg (343.66 KiB) Viewed 11404 times
- IMG_8412.jpeg (324.49 KiB) Viewed 11404 times
- IMG_8413.png (1.83 MiB) Viewed 11404 times
JimCarry
Re: Good news on solving the problem of input delay
so i dont get anything you found a fix or you dont,adrenaline settings what do you mean by that? also can you give a link to the device you buy?Inputlagger91 wrote: β13 May 2025, 17:06Hello again from a guy from Russla. I won't write much, because it's already night, but I want to share the good news, recently I've been experimenting a lot with the settings of the Adrenaline application from amd and I think I did something and the game became better (cs2), it started to register better and the mouse is more, in short, it's playable, but the network filter started to make a lot of noise and I decided to change it. I bought a matihur (hifi) network filter today, but after hooking everything up to it, I caught a floating mouse again and so on, then I decided to leave only the monitor in it, and the computer in a separate outlet, reset the adrenaline settings, and set everything up again so that at least it was playable again. But later I decided to put the computer in the filter again and felt an improvement and this is not a placebo, even later I decided to take a risk again and reset all the settings and it didn't get worse, the main improvement in addition to a sharp mouse and more accurate aiming is controlled shooting with single bullets from such weapons as AK47 and M16, which has not happened since csgo. I will attach a photo of the filter. And I will try to keep you informed. I apologise for my English, I use a translator.
ablemor
its from aliexpress snake oil.
JimCarry
Inputlagger91
I tried different settings, such as gpu scaling, fps restriction, in a word, I played with the settings, and forgot to mention that at the same time I switched to 16:9 resolution 1920x1080 in the window. And about this network filter, we have a trading platform and there I have a person who does not hide that they are from China, and he has already sold more than 100 of them, at the same time, he is not familiar with my problem, but about the interference he said that somehow one rich acquaintance decided to buy this filter from him and helped him in his problem with hifi equipment, remove some guls there, I will not say what specifically, because I do not understand this, but that acquaintance used such filters that cost much more than 500-1000 dollars and they did not help him, And this one surprisingly helped, I won't throw a link, but you can score the model in the browser and the first line will most likely be given to you by Ali express, but I'm a diva in Moscow, I didn't want to wait and bought it on the same day from this person, I'm not sure that it will help everyone, but I feel 100% improvements, not a placebo, but I bought it for 50-60 dollars.
- IMG_8414.jpeg (2.19 MiB) Viewed 11286 times
JimCarry
ok thanks so in your case works nice,now what are the improvments you are saying can you describe what was before the device and now with it ? did you do some benchmakrs fps net etc ?Inputlagger91 wrote: β14 May 2025, 00:01I tried different settings, such as gpu scaling, fps restriction, in a word, I played with the settings, and forgot to mention that at the same time I switched to 16:9 resolution 1920x1080 in the window. And about this network filter, we have a trading platform and there I have a person who does not hide that they are from China, and he has already sold more than 100 of them, at the same time, he is not familiar with my problem, but about the interference he said that somehow one rich acquaintance decided to buy this filter from him and helped him in his problem with hifi equipment, remove some guls there, I will not say what specifically, because I do not understand this, but that acquaintance used such filters that cost much more than 500-1000 dollars and they did not help him, And this one surprisingly helped, I won't throw a link, but you can score the model in the browser and the first line will most likely be given to you by Ali express, but I'm a diva in Moscow, I didn't want to wait and bought it on the same day from this person, I'm not sure that it will help everyone, but I feel 100% improvements, not a placebo, but I bought it for 50-60 dollars.
Inputlagger91
There's nothing to describe here, everything is like everyone else, a floating mouse, a bad hitreg and so on. I didn't do the tests, I wrote about the improvements above, the main thing that caught my eye sharply was the control over single shots, 1 click 1 bulletJimCarry wrote: β14 May 2025, 00:09ok thanks so in your case works nice,now what are the improvments you are saying can you describe what was before the device and now with it ? did you do some benchmakrs fps net etc ?Inputlagger91 wrote: β14 May 2025, 00:01I tried different settings, such as gpu scaling, fps restriction, in a word, I played with the settings, and forgot to mention that at the same time I switched to 16:9 resolution 1920x1080 in the window. And about this network filter, we have a trading platform and there I have a person who does not hide that they are from China, and he has already sold more than 100 of them, at the same time, he is not familiar with my problem, but about the interference he said that somehow one rich acquaintance decided to buy this filter from him and helped him in his problem with hifi equipment, remove some guls there, I will not say what specifically, because I do not understand this, but that acquaintance used such filters that cost much more than 500-1000 dollars and they did not help him, And this one surprisingly helped, I won't throw a link, but you can score the model in the browser and the first line will most likely be given to you by Ali express, but I'm a diva in Moscow, I didn't want to wait and bought it on the same day from this person, I'm not sure that it will help everyone, but I feel 100% improvements, not a placebo, but I bought it for 50-60 dollars.
Inputlagger91
I bought a filter only yesterday, there was little time for the game, today after work I will still see what and how everything is going
Asesino34
If you plug the monitor into a dedicated outlet β where the only thing receiving power is the monitor β thereβs a difference. You should try connecting the monitor without that device you bought, and plug the PC separately, to see whether the difference comes from the device or from using a separate outletInputlagger91 wrote: β13 May 2025, 17:06Hello again from a guy from Russla. I won't write much, because it's already night, but I want to share the good news, recently I've been experimenting a lot with the settings of the Adrenaline application from amd and I think I did something and the game became better (cs2), it started to register better and the mouse is more, in short, it's playable, but the network filter started to make a lot of noise and I decided to change it. I bought a matihur (hifi) network filter today, but after hooking everything up to it, I caught a floating mouse again and so on, then I decided to leave only the monitor in it, and the computer in a separate outlet, reset the adrenaline settings, and set everything up again so that at least it was playable again. But later I decided to put the computer in the filter again and felt an improvement and this is not a placebo, even later I decided to take a risk again and reset all the settings and it didn't get worse, the main improvement in addition to a sharp mouse and more accurate aiming is controlled shooting with single bullets from such weapons as AK47 and M16, which has not happened since csgo. I will attach a photo of the filter. And I will try to keep you informed. I apologise for my English, I use a translator.
JimCarry
ok but,please try this stuff also,buy the usb nic i i bought and i wrote in the forum,then use the settings i show,then use the router tweak @Syykfk show,and then i can bet with you on money that you are gonna feel 20 times more better then now with your device ?Inputlagger91 wrote: β14 May 2025, 00:46There's nothing to describe here, everything is like everyone else, a floating mouse, a bad hitreg and so on. I didn't do the tests, I wrote about the improvements above, the main thing that caught my eye sharply was the control over single shots, 1 click 1 bulletJimCarry wrote: β14 May 2025, 00:09ok thanks so in your case works nice,now what are the improvments you are saying can you describe what was before the device and now with it ? did you do some benchmakrs fps net etc ?Inputlagger91 wrote: β14 May 2025, 00:01I tried different settings, such as gpu scaling, fps restriction, in a word, I played with the settings, and forgot to mention that at the same time I switched to 16:9 resolution 1920x1080 in the window. And about this network filter, we have a trading platform and there I have a person who does not hide that they are from China, and he has already sold more than 100 of them, at the same time, he is not familiar with my problem, but about the interference he said that somehow one rich acquaintance decided to buy this filter from him and helped him in his problem with hifi equipment, remove some guls there, I will not say what specifically, because I do not understand this, but that acquaintance used such filters that cost much more than 500-1000 dollars and they did not help him, And this one surprisingly helped, I won't throw a link, but you can score the model in the browser and the first line will most likely be given to you by Ali express, but I'm a diva in Moscow, I didn't want to wait and bought it on the same day from this person, I'm not sure that it will help everyone, but I feel 100% improvements, not a placebo, but I bought it for 50-60 dollars.
