Dirty Power & Stability
Coldplayer
Post by Coldplayer » 14 May 2025, 22:53
Saw something interesting before,
https://youtu.be/5Xh9LDANm0o?t=1011
Linus was having issues overclocking and running a computer and then after he plugs it into what looks like to be an online UPS then after he runs his computer stable fine. Was shocked that this would actually make a quantifiable difference, I was always under the assumption if the power was bad it simply just wouldn't work.
Wondering if there are any power conditioners/power boards or anything that do something similar without needing to buy a power station or ups.
amorou
Re: Dirty Power & Stability
Post by amorou » 15 May 2025, 04:21
Coldplayer wrote: ↑
14 May 2025, 22:53
Well he said there is always problm in this "corner" of building.
Probably voltage going there drops a lot.
If it is voltage it got nothing to do with our issue
dervu
Post by dervu » 15 May 2025, 05:31
There's no big enough audience for that for them to do episode on this topic.
Also showing such issue live would mean having whole PC industry attack them, because it's negative publicity.
spkii
Post by spkii » 16 May 2025, 02:38
Coldplayer wrote: ↑
14 May 2025, 22:53
Its not an Online UPS, its a Power Station that he uses on video. (Like EcoFlow Delta Pro or similar). I have one: EcoFlow Delta Pro, tried it offgrid (Battery mode) and same problems....
