Offgridding PC on Battery for Under $400 -- Be Your Own Power Company For Cheap -- 12.8V 100AH lithium-iron batteries
spkii
Re: Offgridding PC on Battery for Under $400 -- Be Your Own Power Company For Cheap -- 12.8V 100AH lithium-iron batterie
Post by spkii » 06 May 2025, 11:24
Its working better since bios Update but not fixed yet at all, any suggestions guys?
Hyote
Post by Hyote » 06 May 2025, 13:10
spkii wrote: ↑
06 May 2025, 11:24
Tinfoil around IO shield.
spkii
Post by spkii » 07 May 2025, 05:56
Hyote wrote: ↑
06 May 2025, 13:10
spkii wrote: ↑
06 May 2025, 11:24
I will try it. Someone tried this?: https://www.amazon.es/dp/B0CW6GFP4R?ref ... asin_title
ZINZIRIO
Post by ZINZIRIO » 18 May 2025, 16:45
So someone was able to solve this with batteries?
I'm thinking of buying this.
InputLagger
Post by InputLagger » 18 May 2025, 22:32
spkii wrote: ↑
20 Mar 2025, 02:45
Hyote wrote: ↑
19 Mar 2025, 17:46
spkii wrote: ↑
19 Mar 2025, 14:41
Well, it didnt fixed the issue, IDK if its body related or what.... I came back to connect all things to House, Working perfect for 3 or 4 hours, then starts slow down as every time we tried this...
That's very disheartening but good to know.
In my case, i switched house 3 times (same City, in Spain). 2 Different computers, different peripherals... All Software tweaks... Tried with Humidifier, SAI, UPS, and now this offgrid Battery (2200€ cost).... I think problem now is on Body radiance or RFI? IDK guys.
Record a video and send to tech youtubers or bloggers (fingers crossed)
Cyanide_
Post by Cyanide_ » 07 Jun 2025, 18:36
Tried Anker 535 500w power station (enough for gaming for 1-2 hours) and mobile internet. Disconnected all ethernet wires, router, shut down the mains, and played completely off grid with no power in apartment. No luck, maybe got very tiny improvement. Must be EMI/RFI in the air, which sucks.
ZINZIRIO
Post by ZINZIRIO » 07 Jun 2025, 23:52
In your case, doesnt it always work? In my case, it works perfectly the first time, but everything gets worse after playing for a while... I've tried absolutely everything... I have to leave the PC on the desktop for about 30 minutes, and when I come back, the problem is gone. It can't be EMI in my case.
Post by Slender » 09 Jun 2025, 01:51
ZINZIRIO wrote: ↑
07 Jun 2025, 23:52
that is your room
ZINZIRIO
Post by ZINZIRIO » 09 Jun 2025, 23:22
Slender wrote: ↑
09 Jun 2025, 01:51
ZINZIRIO wrote: ↑
07 Jun 2025, 23:52
that is your room
What are you talking about?
Post by Slender » 09 Jun 2025, 23:25
ZINZIRIO wrote: ↑
09 Jun 2025, 23:22
Slender wrote: ↑
09 Jun 2025, 01:51
ZINZIRIO wrote: ↑
07 Jun 2025, 23:52
that is your room
your room cause your problems
