A few things to try
Hyote
Re: A few things to try
Post by Hyote » 23 May 2025, 08:16
KrendeLь wrote:
23 May 2025, 05:30
I once applied a tweak on the mouse for windows 10 from a comrade with the nickname “Hyote” and after that double clicks on folders stopped working. So his “tweaks” are really dangerous :lol: be careful!!! I do not advise you to change “DoubleClickHeight” and “DoubleClickWidth” to “-” value. Leave it at the default.
Their values don't change, they are deleted altogether. Yes, there are risks if you don't know what you are doing.
dermodemon
Post by dermodemon » 23 May 2025, 12:39
another placebo regedit tweak :D
Hyote
Post by Hyote » 26 May 2025, 15:22
Here is another placebo tweak to try:
HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Executive
PriorityQuantumMatrix 0
WastedEmit
Post by WastedEmit » 27 May 2025, 12:11
Nvm this post. Apparently just a random bad boot out of nowhere that coincided with me trying this reg edit. RAM related fps drop I believe. Tried the reg edit again without noticing any difference with or without.
Hyote
Post by Hyote » 28 May 2025, 14:44
WastedEmit wrote:
27 May 2025, 12:11
DebugPollInterval 250 made windows run at 5fps for me. Even audio was lagging. Deleted the entry and it went back to normal. :|
Many settings like this one don't run well for other people but run flawlessly for me. I don't know if it's related to Windows components or hardware.
Hyote
Post by Hyote » 11 Jun 2025, 00:39
WastedEmit wrote:
27 May 2025, 12:11
Try setting it to 0, which completely disables the setting. By default Windows uses decimal 100.
