XHCI hand-off
Syykfk
Re: XHCI hand-off
Post by Syykfk » 18 Jun 2025, 09:07
Hyote wrote: ↑
15 Jun 2025, 12:43
Syykfk wrote: ↑
15 Jun 2025, 06:54
Hyote wrote: ↑
14 Jun 2025, 11:34
I have to correct my previous reply, because it is definitely better to keep this enabled, and it was a major cause of desync for me.
Do you mean that disabling XHCI hand-off will cause desync?
Yes, major desync. It's good to revisit some settings.
Ok, thanks for the reply, I will try it
