Windows 10/11 Variable Refresh Rate
Igor2023
Post by Igor2023 » 21 Apr 2023, 02:23
Hello! I apologize for my English, I write through the Google translator.
Sorry, if this question has already been asked, redirect, please.
There is a monitor with Free-Sync supported by NVIDIA (ASUS VG258Q 24.5" 144 Hz 1920х1080). In nVidia Control Panel Enabled "G-Sync in Full Screen Mode".
In the "Parameters/display/settings of graphics" in Windows 10, it is possible to enable or disable "Variable Refresh Rate" that you recommend: do you need to turn it on there? Will there be any conflicts between Nvidia control panel and Windows settings?
Thank you!
i7-8700K
Gigabyte Z370 AORUS Gaming K3
Kingston 2x16GB 3000 MHz HyperX Predator
MSI GeForce RTX 2080 Super Gaming X Trio
SSD SAMSUNG 850 Pro 256GB
Re: Windows 10/11 Variable Refresh Rate
Post by RealNC » 21 Apr 2023, 05:40
Enable both. There is no conflict. The Windows setting just allows g-sync to work with some DX12 games from the app store (IIRC.) Both settings need to be enabled. If you ever want to disable g-sync, you only need to do that in the nvidia panel. G-sync will be disabled even if the Windows setting is enabled.
So just set the Windows setting to enabled and forget about it.
Kyouki
Post by Kyouki » 21 Apr 2023, 07:13
Starting with Windows 10 version 1903, Microsoft has added a new toggle in Graphics Settings for variable refresh rate. Variable refresh rate (VRR) is similar to NVIDIA’s G-SYNC and VESA DisplayPort Adaptive-Sync.
This new OS support is only to augment these experiences and does not replace them. You should continue to use G-SYNC / Adaptive-Sync normally. This toggle doesn’t override any of the settings you’ve already configured in the G-SYNC or Adaptive-Sync control panels.
This new toggle enables VRR support for DX11 full-screen games that did not support VRR natively, so these games can now benefit from your VRR hardware.
You won’t see the slider unless your system has all of the following. If any of these are missing, you will not see the toggle and the feature will not be enabled for you.
- Windows 10 version 1903 or later
- A G-SYNC, FreeSync, or Adaptive-Sync capable monitor
- A GPU with WDDM 2.6 or above drivers, that supports G-SYNC / FreeSync / Adaptive-Sync and this new OS feature
Source: https://www.tenforums.com/tutorials/133 ... -10-a.html
RamenRider
Post by RamenRider » 10 Jun 2023, 05:22
Real question is, does it introduce any lag? Or does it actually allow FreeSync to fully utilized as well?
Astyanax
Post by Astyanax » 26 Jun 2025, 21:51
RealNC wrote:
21 Apr 2023, 05:40
DX11 games that used legacy bitblit swapchains in a composited window, hence it also affects Applications that use d3d11 bitblit swapchaisn, such as windows terminal, chrome, steam, discord, etc.
mmmm. no, do not.
Use it when you need it, leave it off otherwise.
