No FPS gaming possible
LaggyTyp
Re: No FPS gaming possible
Post by LaggyTyp » 23 Jul 2025, 05:33
Wireshark > Filter > udp.port == 3659 > No entries
File is ~15Mb
LaggyTyp
Post by LaggyTyp » 23 Jul 2025, 05:46
Screenshot (27).png (73.56 KiB) Viewed 1767 times
Filter:
udp.port == 3659
udp.port == 9999
udp.port == 52553
No entries :?: :?: :?:
LaggyTyp
Post by LaggyTyp » 23 Jul 2025, 06:32
I found the error. My FritzBox ignores UDP data traffic. :roll:
I have now recorded it with “RawCap.exe”.
Screenshot (29).png (256.61 KiB) Viewed 1754 times
I can't interpret the values?
Screenshot (36).png (123.37 KiB) Viewed 1750 times
1000WATT
Post by 1000WATT » 23 Jul 2025, 07:26
LaggyTyp wrote: ↑
22 Jul 2025, 20:35
What works best so far (but not always) is when I increase my outbound ping by about 35ms.
You can try to achieve the ping/jitter ratio like ChristophSmaul1337 13ping 0.5jitter 4% instead of 20ping 2jitter 10% like you have. Increase the ping to 100.
This is the result from Moscow.
LaggyTyp
Post by LaggyTyp » 23 Jul 2025, 07:59
BF2042-Gameplay (Normal)
Screenshot (36).png (123.37 KiB) Viewed 1730 times
BF2042-Gameplay (+70ms Outbound-Ping)
Screenshot (38).png (106.21 KiB) Viewed 1730 times
Can someone rate this for me?
LaggyTyp
Post by LaggyTyp » 23 Jul 2025, 08:38
+35ms inbound and +35ms outbound
Screenshot 2025-07-23 153550.png (121.63 KiB) Viewed 1714 times
My buffers (NIC) are both set to 1024. Maybe I need to increase this if I want to play with high ping (50-80ms)?
only outbound = good
inbound + outbound = bad (delayed)
PS: sorry for doublepost
LaggyTyp
Post by LaggyTyp » 23 Jul 2025, 12:28
I can summarize:
What really helps:
1.) Flow Control = disable
2.) Large Send Offload V2 (2x) = disable
3.) RSC = disable
4.) Add artificial outbound ping = to get to about 60ms (total) (but doesn't always help!)
I think it's my IPS. DoCis internet is shared internet. It's fine in the morning and at noon, and complete bullshit from noon to night.
I need to go back to VDSL or 5G GigaCube (Vodafone). I'm desperate.
1000WATT
Post by 1000WATT » 23 Jul 2025, 13:15
Test +35 ms outbound only. Don't change inbound .
LaggyTyp
Post by LaggyTyp » 23 Jul 2025, 15:27
I always set the outbound lag to +34ms, but it's not always good.
Real talk: I sometimes play with exit lag, and it's good. I sometimes play with +34ms, and it's good. I sometimes adjust settings in my network card's options, and it's good. I sometimes adjust something in my router's settings, and it's good. Sometimes I also adjust something in the registry, and it's good.
But the truth is: If it's good, then it's good without these changes. It's not good because of the changes, but because the internet (ISP) is good at the time (The game feels more direct, and I can really make a difference. I'm a player who can turn a lost round.).
For my packet tracking, I played a lot more than usual today, and there was this one round. WOW! The enemies were dropping like flies. With one magazine (20 rounds), I easily took out five enemies in a row. A few hours later (no changes), I needed 1-2 magazines for a single enemy.
Once the problem occurs, it feels like you're playing at 500ms, but the display shows 14ms.
In my case, it could also be a combination of ISP + game engine (lag compensation) + low ping.
I'm extremely frustrated. I only have this one hobby, and I have to suffer from these problems.
1000WATT
Post by 1000WATT » 23 Jul 2025, 17:02
LaggyTyp wrote: ↑
23 Jul 2025, 15:27
If there are no simple solutions, then perhaps the old topic of this forum will help.
The ideas in that topic can be implemented without a programmer, but not completely.
viewtopic.php?f=10&t=8451
In extreme cases, you can try the factory solution. But I don't know how well it works. Maybe it's just marketing.
https://youtu.be/IElhhEi70Pg?t=133
