roginthemachine wrote: ↑02 Aug 2025, 00:14
The new rtings test is very clever, allowing you to eyeball the MPRT very easily.
What’s very exciting about these displays’ particular quirk, where brightness and pulse width are interlinked, is that if we are somehow able to squeeze more peak brightness from the display, we can use that extra headroom to lower the brightness setting further and get a shorter pulse width/MPRT. you can effectively cash in brightness for motion clarity.
My quick research online suggests that the extra options to improve max out brightness on Samsung displays involve the service menu - where you can disable ASBL, and increase peak luminance values of specific window sizes
https://youtu.be/VkV-pkc2ehA?feature=shared
I sure hope there's a way to improve the real scene brightness in HDR Game Mode.
The fact that you can improve motion further by sacrificing whichever amount of brightness you can spare is a big deal, especially if you start from 120/144hz (haven't tested the latter due to splitter incompatibility). So yes in a sense the higher the potential brightness, the better the potential motion clarity.
So hopefully someday soon I will feel confident in safely boosting the brightness on mine (knowing that it is already one of the brightest out of the box with Game Mode HDR being an slight outlier).
I mean like I said many times now, I would gladly buy an OLED that has low-lag interpolation to 240hz, to take my G1's spot in my Office/Home Theater room, I can forget about rolling-scan BFI, I can live with higher MPRT if the benefits outweigh the downsides compared to the ageing G1 (much higher brightness, and no BFI => No brightness loss).
I'm not however willing to go back to a small 1080p monitor to get higher refresh rates I'll never reach by "natural" means.
I don't even think there are 500hz+ 1080p OLEDs on the market anyway, all I could find on RTINGS were 540hz LCDs for my comparison earlier (for the record, when there were several monitors with the same specs, I picked the shot which looked the clearest/less smeary).
But then by the time most OLED TVs reach 240hz, these Samsung LCDs will be able to reach the same refresh rate AND, barring some unfortunate nerf, still push things further by lowering backlight pulse width.
Realistically at this moment, RTINGS test is the best tool we have to "hierarchize" motion clarity, and in the current reality, in TVs, of 4K 120>165hz we live in, Samsung LCDs stand head and shoulder above the rest.
I'm sorta interested in the PG27AQDP (1440p 480hz) OLED monitor, but again the brightness is lackluster compared to TVs.
I love Lossless Scaling, and am looking forward to an universal, straightforward implementation of CRT Simulation, but at this moment I do not feel like the former is a viable solution for ultra-high refresh (performance issues on too high multipliers), the latter is super nice in concept and will get more and more interesting as refresh rates increase, but in terms of raw performance, 120hz backlight strobing on an LCD can theoretically go much beyond the maximum 540hz clarity we have in lowly 1080p monitors.
Therefore LCD backlight strobing is not obsolete at this point, therefore having access to the gold standard in both TVs and monitors remains desirable, even as companion pieces to OLEDs that have other strengths, QED.
In the future there are many things to wish for on top of an increase in resolution and refresh rates.
-A return of rolling-scan BFI in OLED, preferably one stronger than seen before to competes with LCD backlight strobing
-An increase in OLED fullscreen brightness to help with the above.
-Improved Low-Lag interpolation with less artifacts, adopted by other brands than Samsung.
-Improved LCD backlight strobing by other brands than Samsung.
-An increase in Mini-LED zone count (star fields do tend to look a lot better on OLED)
-RGB Mini-LED backliighing.
Both technologies have room for improvement and some ways to bridge the gap between one another.
As far as Micro-LED is concerned, from what I understand it is simply a better OLED but I believe it behaves mostly the same when it comes to motion (i.e. sample and hold, not particularly easier to strobe).
I also have no idea what motion clarity is like on the various projector technologies, from what I gather it is nothing special.
