I just fixed my input lag and it won't come back
Sandy
Here's the evidence of input lag I captured
https://www.youtube.com/shorts/lHv6qH_Ud2w
These links are related discussions by others on the Internet
viewtopic.php?f=10&t=9083
https://www.overclock.net/threads/optic ... s.1469332/
https://www.mouse-sensitivity.com/forum ... -wits-end/
- naporitan
Re: I just fixed my 50% input lag and it won't come back
I have several mousepad 1. Meow ultraaceaim 2. Esport tiger 3. Aqua control speed 4. Zowie gsr and I get good gaming experience only on zowie gsr
My mouse - wlmouse ying, 1khz, 800 dpi.
- naporitan
For many of my mousepads, I need to set lod 0.7 mm. The thing is that the mouse sensor is like a camera and when the mouse lod is set too high, the sensor does not see the texture of the pad and therefore the micro aim disappears and the effect of low dpi appears, as well as the effect of mouse floating.
Sandy
I actually fixed 100% of my input lag. I couldn't believe it!naporitan wrote: ↑18 Aug 2025, 00:38For many of my mousepads, I need to set lod 0.7 mm. The thing is that the mouse sensor is like a camera and when the mouse lod is set too high, the sensor does not see the texture of the pad and therefore the micro aim disappears and the effect of low dpi appears, as well as the effect of mouse floating.
It turns out I didn't have any power system lag at all. I've gone through five monitors over the years, and the real culprit was actually a problem with my mouse and mousepad.
amorou
Sarcasm right ?Sandy wrote: ↑18 Aug 2025, 10:16I actually fixed 100% of my input lag. I couldn't believe it!naporitan wrote: ↑18 Aug 2025, 00:38For many of my mousepads, I need to set lod 0.7 mm. The thing is that the mouse sensor is like a camera and when the mouse lod is set too high, the sensor does not see the texture of the pad and therefore the micro aim disappears and the effect of low dpi appears, as well as the effect of mouse floating.
mago
MouseTester show some diff ? between the pads
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
Sandy
- Slender
mago
maybe it will be beneficial for others to see those differnce
Sandy
