I just fixed my input lag and it won't come back
Sandy
Re: I just fixed my 50% input lag and it won't come back
Post by Sandy » 24 Aug 2025, 00:43
mago wrote:
19 Aug 2025, 18:33
maybe it will be beneficial for others to see those differnce
I'll update my question.
I can't track the target correctly on any mouse pad. However, I can track it with zero lag on a wooden table, cardboard, and some fabric sheets.
I found someone else experiencing the exact same problem as me.
https://forums.tomshardware.com/threads ... ag.3659517
amorou
Post by amorou » 24 Aug 2025, 13:31
Sandy wrote:
24 Aug 2025, 00:43
mago wrote:
19 Aug 2025, 18:33
Mouse skates glide on table easily ,or thicker mousepads will hold mouse more and will feel sluggish but precise to flick/stop , you might mistake lag with that
Sandy
Post by Sandy » 24 Aug 2025, 22:47
amorou wrote:
24 Aug 2025, 13:31
Sandy wrote:
24 Aug 2025, 00:43
mago wrote:
19 Aug 2025, 18:33
No, I rely on evidence to determine if there is input lag. I don't rely on feelings, that's not accurate.
amorou
Post by amorou » 25 Aug 2025, 04:16
Sandy wrote:
24 Aug 2025, 22:47
amorou wrote:
24 Aug 2025, 13:31
Sandy wrote:
24 Aug 2025, 00:43
mago wrote:
19 Aug 2025, 18:33
Do you think you being able to track or not is a evidence ?
Sandy
Post by Sandy » 25 Aug 2025, 22:14
amorou wrote:
25 Aug 2025, 04:16
Sandy wrote:
24 Aug 2025, 22:47
amorou wrote:
24 Aug 2025, 13:31
Sandy wrote:
24 Aug 2025, 00:43
I took a video and you can check it out. On other surfaces, this delay is completely non-existent. So far, I haven't found a mouse pad with zero delay.
https://www.youtube.com/shorts/lHv6qH_Ud2w
daemonjax
Re: I just fixed my input lag and it won't come back
Post by daemonjax » 27 Aug 2025, 15:39
I use these cheap mousepads:
https://www.amazon.com/dp/B088539GLT?re ... tle_1&th=1
Razer Gigantus V2 Cloth Gaming Mouse Pad (Medium): Thick, High-Density Foam - Non-Slip Base - Classic Black
$10
They seem fine to me.
Only downside is no rgb lights. /jk
Sandy
Post by Sandy » 27 Aug 2025, 22:33
daemonjax wrote:
27 Aug 2025, 15:39
$10
A mouse pad has only one purpose, and that is to provide good tracking. I tested the Artisan Ninja FX Zero today and did a lot of testing. I found that this mouse pad has very low input latency. The only drawback is that it is too expensive.
