Life saving zero input lag glitch on 1680x1050 screen resolution
revengeatc
Re: Life saving zero input lag glitch on 1680x1050 screen resolution
Post by revengeatc » 30 Jul 2025, 18:47
Wow. This game flows like butter. Every bullet fired goes straight to the head. The mouse rotates equally in all directions. I tried the resolution, and it had a direct effect. However, with five years of experience, I can tell you that everything will be outdated in a few days or so. Did it get outdated on yours? I suppose the bugs I know exist aren't allergic to this resolution?
InputLagger
Post by InputLagger » 21 Aug 2025, 02:35
NARCO wrote:
14 Jun 2025, 04:32
Bro wow I have a 27" 2560x1440 @270hz ROG monitor and when i changed the res like u said and after i reset my pc no more heavy mouse felling
i will update on this post if it work for long time .
https://youtu.be/V-QLzXjFUHo
Fix still works for you?
dermodemon
Post by dermodemon » 21 Aug 2025, 14:05
InputLagger wrote:
21 Aug 2025, 02:35
NARCO wrote:
14 Jun 2025, 04:32
yes. still only one playable resolution for me. probably i have a faulty monitor or something. i don't know. but now i am playing only in this resolution
daemonjax
Post by daemonjax » 27 Aug 2025, 15:46
When you drop resolution like that, your lcd's pixel clock doesn't have to run at max speed. Maybe it can't handle max speed, or anything close to that speed. That's all I got. ¯\_(ツ)_/¯
jadlr
Post by jadlr » 29 Aug 2025, 08:53
dermodemon wrote:
21 Aug 2025, 14:05
InputLagger wrote:
21 Aug 2025, 02:35
NARCO wrote:
14 Jun 2025, 04:32
Can you please open CRU and export the settings and give us the .bin file?
dermodemon
Post by dermodemon » 02 Sep 2025, 10:51
jadlr wrote:
29 Aug 2025, 08:53
dermodemon wrote:
21 Aug 2025, 14:05
InputLagger wrote:
21 Aug 2025, 02:35
NARCO wrote:
14 Jun 2025, 04:32
sure but don't break your pc please :D
https://drive.google.com/file/d/1N4i-qj ... sp=sharing
