same on 7
Bad mousetester graph when videocard is on
- Slender
Re: Bad mousetester graph when videocard is on
- win7.png (111.86 KiB) Viewed 8591 times
slaver01
I don't know what to use to play (fortnite).
w10 i have more fps than w7. Should I look more at the graph or at the fps?
W10 21h1: driver 471.96
- Max 719 fps
- 1% 91 fps
- 0.1% 39 fps
W7 sp1: driver 471.96
- Max 625 fps
- 1% 89 fps
- 0.1% 37.5 fps
- Max 719 fps
- 1% 91 fps
- 0.1% 39 fps
- Max 625 fps
- 1% 89 fps
- 0.1% 37.5 fps
- Slender
if fortnite use dx11, w10 better.
try 8.1
- Slender
i try to CLRTC, maybe it work, see later
- win10.png (160.42 KiB) Viewed 8505 times
slaver01
- Slender
it is like factory reset bios with memory cache, but it not work in my case. same problem..
2 variants:
1) motherboard
2) emi, ha-ha
2 variants:
1) motherboard
2) emi, ha-ha
slaver01
- Slender
im use last revios, 0.5ms timer with 1 core affinity on my pci-e usb 2.0 card and useplatformtick no
celomu
Hello!
Well, is there any news?
I also encountered this problem!
I noticed when music is playing (via an external DAC) this problem occurs more often!
I blame not only the OS but also the chipset!
(I've been suffering for 3 days already, looking for the root of the problem.
and in general I've been suffering for more than 5 years, I'm extremely sensitive to frame drops and sound quality... and where people will say it plays normally, the picture is normal, the song sounds good, I'll say... something's not right here!))
- Slender
i think it dwm.celomu wrote: ↑01 Sep 2025, 15:01Hello!
anyway, im not fix that.
move gpu and usb controller to different cores may little bit fix it.
also try play with interrupt steering.
