No FPS gaming possible
1000WATT
Re: No FPS gaming possible
Post by 1000WATT » 07 Sep 2025, 11:24
LaggyTyp wrote:
07 Sep 2025, 06:24
On bad days and rounds, the upload bar is much higher and then also has jitter. The packets from the game server reach me demonstrably faster than my packets reach the game server.
There's a discrepancy between download and upload.
It's like watching a movie where the video and audio no longer match (are out of sync).
On the third page of this topic.
1000WATT wrote:
05 Jul 2025, 15:34
LaggyTyp wrote: Internet:
- Docsis Cable
- 1000 Mbps download / 50 Mbps upload
- Ping: 12-15ms (in-game)
- FritzBox 6690 (with LAN cable)
If it's not too much trouble, show the results https://www.waveform.com/tools/bufferbloat . But first limit your internet speed to 1/4 or 1/8 of the current one. I'm interested in the difference in ping for download and upload.
1000WATT wrote:
06 Jul 2025, 02:48
LaggyTyp wrote:
05 Jul 2025, 19:49
- No gamer is experiencing bufferbloat (or they're doing something really wrong)
That's why I asked for a speed limit. I don't care about buffer overflows.
LaggyTyp
Post by LaggyTyp » 07 Sep 2025, 13:57
I've already tested everything here.
- Upload ping manipulated
- Download ping manipulated
- Download and upload ping manipulated
- Receive packets manipulated
- Send packets manipulated
- Receive and send packets manipulated
- Download bandwidth manipulated
- Upload bandwidth manipulated
- Download and upload bandwidth manipulated
There are a few things that help, BUT IF THEY HELP, it works without them. Once the problem is there (upload jitter), NOTHING helps. No Windows option, no manipulation, no router, no VPN... simply nothing!
Why shouldn't the game crash if the download is so different from the upload?
The game shows, for example, 15 ms.
From game server to you = 5 ms
From you to game server = 10 ms
Of course, this can't work well.
Even if the download area were completely error-free (0ms jitter), you won't just experience upload effects like hitreg. The entire game will be thrown off track and everything will be messed up. Of course!
LaggyTyp
Post by LaggyTyp » 07 Sep 2025, 13:59
By the way, the CS2 documentation is wrong.
00-00 0:0
Blue is downloading.
Red is uploading.
Ghosty_Ind
Post by Ghosty_Ind » 07 Sep 2025, 15:05
LaggyTyp wrote:
07 Sep 2025, 13:59
00-00 0:0
Red is uploading.
Hey LaggyTyp,
I am back.
Everyone, test this - uninstall all your chromium based browsers. Chrome, Brave, Mozilla, Opera.. Uninstall all of them, play your game, and let me know the feedback :) .. Fingers crossed !!!
Trust me… Do this and tell me what you see..
Hyote
Post by Hyote » 07 Sep 2025, 15:41
Ghosty_Ind wrote:
07 Sep 2025, 15:05
LaggyTyp wrote:
07 Sep 2025, 13:59
00-00 0:0
Red is uploading.
Hey LaggyTyp,
I am back.
That is genius, thanks for sharing this solution.
kriegsnake
Post by kriegsnake » 07 Sep 2025, 15:50
Ghosty_Ind wrote:
07 Sep 2025, 15:05
LaggyTyp wrote:
07 Sep 2025, 13:59
00-00 0:0
Red is uploading.
Hey LaggyTyp,
I am back.
Mate I am using edge for 4 years and have this shit :)
Ghosty_Ind
Post by Ghosty_Ind » 07 Sep 2025, 15:55
kriegsnake wrote:
07 Sep 2025, 15:50
Ghosty_Ind wrote:
07 Sep 2025, 15:05
LaggyTyp wrote:
07 Sep 2025, 13:59
00-00 0:0
Red is uploading.
Hey LaggyTyp,
I am back.
Don’t know. Removed all that shits and can’t believe they were the reason. Have a check that any other browser is not installed ?
danbmx
Post by danbmx » 07 Sep 2025, 16:03
I have an Archer C6 router, sometimes I enable QoS and limit the download and upload to 120. It works well for a couple of matches, but then the desynchronization comes back.
LaggyTyp
Post by LaggyTyp » 07 Sep 2025, 16:04
None of my friends have such problems. These are gamers who even have pre-installed browsers on their pre-built PCs. Some even have multiple browsers installed.
No, no, no, that's not a solution.
For me, it's due to:
- Segment overload (especially upload)
- Jitter
- Hardware solution that bundles packets
A deadly poison.
Ghosty_Ind
Post by Ghosty_Ind » 07 Sep 2025, 16:05
danbmx wrote:
07 Sep 2025, 16:03
Yes used to have same. Try what I mentioned above..
