anyway to deactivate usb interrupt moderation?
petergase
Post by petergase » 09 Sep 2025, 13:24
Hello,
I have to enable core isolation because of anti-cheat, but this causes rweverything to stop working and I can't edit the driver.
Is there a way to change or disable the USB interrupt moderation without Rweverything with core isolation enabled?
Perhaps another Xhci USB driver that Imod has already disabled?
Hyote
Re: anyway to deactivate usb interrupt moderation?
Post by Hyote » 09 Sep 2025, 13:35
petergase wrote: ↑
09 Sep 2025, 13:24
Hello,
I don't think there's a way to do it legitimately without bypassing HVCI.
petergase
Post by petergase » 09 Sep 2025, 14:39
Hyote wrote: ↑
09 Sep 2025, 13:35
petergase wrote: ↑
09 Sep 2025, 13:24
Hello,
anyway to have the same 1:1 mouse feeling like with rweverything and 0 imod?
Hyote
Post by Hyote » 09 Sep 2025, 15:31
petergase wrote: ↑
09 Sep 2025, 14:39
Hyote wrote: ↑
09 Sep 2025, 13:35
petergase wrote: ↑
09 Sep 2025, 13:24
Hello,
I'm not sure if the exact feel can be replaced but setting up other things correctly still matters. The third link below this message has my guide, maybe the Process Priority part at the end can be tried out. Also setting the most active csrss threads to one core, audiodg.exe to one core can bring improvement.
Post by Slender » 10 Sep 2025, 09:17
yes, mcs9990 dont have it
F1zus
Post by F1zus » 10 Sep 2025, 18:36
Slender wrote: ↑
10 Sep 2025, 09:17
How does the mouse feel compared to a direct connection to the CPU USB (AMD)? Does it make sense to buy a separate USB card?
Post by Slender » 11 Sep 2025, 00:20
F1zus wrote: ↑
10 Sep 2025, 18:36
Slender wrote: ↑
10 Sep 2025, 09:17
amd cpu usb 2.0 > amd cpu usb 3.0 > mcs9990 > GL 2.0 > intel usb controller
for intel yes, it make sence
petergase
Post by petergase » 12 Sep 2025, 19:10
Slender wrote: ↑
11 Sep 2025, 00:20
F1zus wrote: ↑
10 Sep 2025, 18:36
Slender wrote: ↑
10 Sep 2025, 09:17
ok I bought one and testing right now
msi mode on or off?
and have u installed a driver?
only mouse or also keyboard and audio?
Is that light on your device also permanently red? I connected the power cable.
Post by Slender » 12 Sep 2025, 23:49
petergase wrote: ↑
12 Sep 2025, 19:10
Slender wrote: ↑
11 Sep 2025, 00:20
F1zus wrote: ↑
10 Sep 2025, 18:36
Slender wrote: ↑
10 Sep 2025, 09:17
msi mode on or off?
there is only non-msi mode.
there is 8 separate controller inside (4 - 1.1, 4 - 2.0), you can connect keyboard and mice.
i dont use power cable for it.
petergase
Post by petergase » 13 Sep 2025, 13:38
Slender wrote: ↑
12 Sep 2025, 23:49
petergase wrote: ↑
12 Sep 2025, 19:10
Slender wrote: ↑
11 Sep 2025, 00:20
F1zus wrote: ↑
10 Sep 2025, 18:36
msi mode on or off?
thats the one I have usb 2.0
and you havent installed any additional drivers?
also somehow it has a msi mode
