anyway to deactivate usb interrupt moderation?
petergase
Hello,
I have to enable core isolation because of anti-cheat, but this causes rweverything to stop working and I can't edit the driver.
Is there a way to change or disable the USB interrupt moderation without Rweverything with core isolation enabled?
Perhaps another Xhci USB driver that Imod has already disabled?
Hyote
Re: anyway to deactivate usb interrupt moderation?
I don't think there's a way to do it legitimately without bypassing HVCI.petergase wrote: ↑09 Sep 2025, 13:24Hello,
petergase
anyway to have the same 1:1 mouse feeling like with rweverything and 0 imod?Hyote wrote: ↑09 Sep 2025, 13:35I don't think there's a way to do it legitimately without bypassing HVCI.petergase wrote: ↑09 Sep 2025, 13:24Hello,
Hyote
I'm not sure if the exact feel can be replaced but setting up other things correctly still matters. The third link below this message has my guide, maybe the Process Priority part at the end can be tried out. Also setting the most active csrss threads to one core, audiodg.exe to one core can bring improvement.petergase wrote: ↑09 Sep 2025, 14:39anyway to have the same 1:1 mouse feeling like with rweverything and 0 imod?Hyote wrote: ↑09 Sep 2025, 13:35I don't think there's a way to do it legitimately without bypassing HVCI.petergase wrote: ↑09 Sep 2025, 13:24Hello,
- Slender
yes, mcs9990 dont have it
- F1zus
- Slender
amd cpu usb 2.0 > amd cpu usb 3.0 > mcs9990 > GL 2.0 > intel usb controller
for intel yes, it make sence
petergase
ok I bought one and testing right now
msi mode on or off?
and have u installed a driver?
only mouse or also keyboard and audio?
Is that light on your device also permanently red? I connected the power cable.
- Slender
there is only non-msi mode.petergase wrote: ↑12 Sep 2025, 19:10ok I bought one and testing right now
msi mode on or off?
there is 8 separate controller inside (4 - 1.1, 4 - 2.0), you can connect keyboard and mice.
i dont use power cable for it.
petergase
thats the one I have usb 2.0Slender wrote: ↑12 Sep 2025, 23:49there is only non-msi mode.
and you havent installed any additional drivers?
also somehow it has a msi mode
- usb.png (10.84 KiB) Viewed 25979 times
- 41Dk3RiuCVL._AC_.jpg (28.35 KiB) Viewed 25981 times
