Trying to recall what was the monitor released this year with scanline BFI done with FALD
betonKruglosuTotchno
Post by betonKruglosuTotchno » 23 Sep 2025, 15:39
I heard a lot about the programmatic BFI:
https://blurbusters.com/crt-simulation- ... -than-bfi/
viewtopic.php?t=10050
but I do not care too much about them. But I do care about some monitor which got released this year which has scanline BFI making it shockingly close to CRT thanks to it's FALD and the brightness limit was great on it too.
I recall it was showcased on Computex 2025 but not yet available. What's the model?
Re: Trying to recall what was the monitor released this year with scanline BFI done with FALD
Post by betonKruglosuTotchno » 23 Sep 2025, 16:04
I probably found it. It's not FALD but rather side backlight used to scan the panel, it's called Dyac2.
https://zowie.benq.com/en-us/knowledge/ ... -dyac.html
Would really love to know if anybody tested it.
Post by betonKruglosuTotchno » 23 Sep 2025, 16:25
Found a review in Japanese and they are doing the pursuit shot wrong lmao.
https://jisakuhibi.jp/zowie-xl2586x
https://jisakuhibi.jp/wp-content/upload ... 63d7ab.jpg
Every shot they take does not have long exposure to capture motion across multiple frames. I feel like a damn genius knowing that pursuit photo should last for several frames and that any photo demonstrating motion clarity should pursue a moving object.
Last edited by betonKruglosuTotchno on 24 Sep 2025, 10:55, edited 2 times in total.
Post by betonKruglosuTotchno » 23 Sep 2025, 16:41
As I understand it from the Rtings review it's basically a gimmick at anything lower than 540 Hz (there are pursuit photos there) because crosstalk is terrible and the pulse is longer at lower refresh rates:
https://www.rtings.com/monitor/reviews/ ... ie-xl2586x
kyube
Post by kyube » 07 Oct 2025, 13:21
betonKruglosuTotchno wrote:
23 Sep 2025, 16:41
Dyac 2 (XL2586X, XL2586X+), ELMB 2 (XG248QSG) and MBR+ (AG246FK6) are all rolling-scan backlight strobing implementations.
I'm not sure whether the BenQ models allow you to adjust the pulse width using Chief's utility.
I recall that not being possible.
Post by betonKruglosuTotchno » 11 Oct 2025, 09:27
kyube wrote:
07 Oct 2025, 13:21
23 Sep 2025, 16:41
Considering how wide a sector of edge backlight is I wonder if it will change anything significantly.
Do any of those use FALD for that?
kyube
Post by kyube » 11 Oct 2025, 10:36
11 Oct 2025, 09:27
Nope, none of those are a full array WLED backlight. They all employ side mounted edge-lit WLED's as a backlight solution.
I do believe there is a FALD rolling scan solution on the market — the Sony Inzone M9 II source
