solved Floaty Mouse- Reproducable fix-
- themagic
Re: solved Floaty Mouse- Reproducable fix-
Completely bullshit...dont listen to this shit...
kadirg
jeffeh12133
could it end up being just the fact that it's a new bios and it's just like the other settings where you change it and it works for a little bit?
jeffeh12133
since you mentioned mouse initialization, could it be just "driver-ranking issues" during mouse installation like this below thread is mentioning or do you think it's entirely something else?
viewtopic.php?f=10&t=9977
ablemor
i tried linux, and it was floaty, so its not driver issue
jeffeh12133
- themagic
mouse infectedjeffeh12133 wrote: ↑30 Sep 2025, 00:53did you try his fix? basically to reinstall the same bios version and try different mouse or what? how could you know if your mouse is "infected"?
what next ? earphones/headsets are infected ?
and what about keyboards ? are they or can be infected too ?
but most important and interesting what with touchpads ? infected ? you know there exist keyboards with touchpad ?
edit:
guys i find better fix and not even a fixed mouse needed to buy or search for lol:
instead of update bios with your new "fixed mouse"...just put a "fixed usb gamepad" (you can even use the ones from your console) and then update bios. should work too or ?
after then just play some games which good for gamepad (example rocket league, fifa..) only and feel the difference haha...
- dervu
I heard this infected theory so many times yet no one dares to send such mouse to anyone to review/check what is wrong with it.
jeffeh12133
has anyone else tried this "fix" apart from the couple who posted earlier? considering trying this. just basically reinstall the same bios + use new mouse i guess? is it still giving you a smooth feeling OP?
ablemor
i found better fix
