my game is really fast in midnight but slow in morning
Sandy
Kyousuke
Re: my game is really fast in midnight but slow in morning
Damn, that sucks. I’ve had the same issue too, no matter how much I upgrade components, input delay never goes away. Everything looks blurry when moving, even offline games. In Souls games, timing deflects is really difficult no matter how much I tried. at midnight my CS2 K/D is around 1.8, but during the day it drops to 1.0 or worse, but also I'm not pro at CS2. Now I just avoid games that are too influenced by input delay.
MontyTheAverage
I have moved different countries... It is still there...Kyousuke wrote: ↑08 Oct 2025, 22:10I also think I won’t find the real answer until I move to another country or at least to a better house, because I’ve already lived in two different houses and used two different ISPs.themagic wrote: ↑08 Oct 2025, 21:36@Kyousuke sry man...
but thats the the trick...![]()
and many here don't know what fix is and what gonna help and right now and specially in your case and im telling you only the full truth right now and no blabla bullshit...
no one knows...
there are no magic fix or something that can improve or anything...
people here are fucked same as you with similar issues and some even worse...and many want too understand how and why things happens and how it works...
и типа в чем фишка ? like, what's the trick ?![]()
Or like in my case Problem: How to get normal online gaming again and like bofore 2018/2019 ??? And go back to this stable state time and whre everything worked somehow normal and for me ???
no one knows...and how...lol
and yes maybe we or me are lacking knowledge...
this chance very possible too.but you already figure it out by yourself....
The thing is, you guys mock me because you assume I haven’t tested any of this, but I’ve spent two years trying everything, from software tweaks to hardware changes. Some things worked for a short time, but the issue always came back.
The only times I’ve truly felt smooth, fast gameplay were after moving to a new place and playing late at night, that’s when everything runs incredibly well. I can’t completely fix the power quality, but if it’s the network, then maybe there’s some software or tweak that could help, which is why I was hoping it was the network’s fault.
However, even though VPNs or ExitLag do improve things a bit, it’s still never the same as playing at night. So it’s very likely that both power and network are major factors affecting my gameplay, not just one of them, but both together.
Atleast consider yourself lucky you don't have the issues at night. I do notice on my end it is better at night also but more inconsistently and not as clear cut as yours.
- Slender
This is very similar to a faulty UPS on your ISP's switch. What is your electrical system like? Do you have the ability to test the neutral/ground resistance?Kyousuke wrote: ↑08 Oct 2025, 22:10I also think I won’t find the real answer until I move to another country or at least to a better house, because I’ve already lived in two different houses and used two different ISPs.themagic wrote: ↑08 Oct 2025, 21:36@Kyousuke sry man...
no one knows...
Kyousuke
then I assume the components can get defected like the other guy has experienced, he seems to fixed it after buy every parts new. unfortunately I don't have that much of money for now and it's a pain to sell them all and buy all new again, also I'm testing in latency mon and it states that nvlddmkm.sys which relates to Nvidia drivers is the top 1 culprit to my high latency, weird, but I have DDU before and nothing changes, maybe I will look into it moreMontyTheAverage wrote: ↑09 Oct 2025, 04:32I have moved different countries... It is still there...Kyousuke wrote: ↑08 Oct 2025, 22:10I also think I won’t find the real answer until I move to another country or at least to a better house, because I’ve already lived in two different houses and used two different ISPs.themagic wrote: ↑08 Oct 2025, 21:36@Kyousuke sry man...
no one knows...
Kyousuke
At my old house there was a grounding connection but in my current apartment it seems they dont even have three prong outlets meaning theres no proper ground. So I once tried using a wire with a clamp to manually connect a ground but it didnt seem to help I also tried using an isolation transformer as a substitute but that didnt work either same with a DC blocker or power filter. Its possible that the grounding system in my apartment is faulty and the wiring in my old house even though it has grounding, it might have also deteriorated, idk, that's why both places could be causing the same issue, just that well if that's the case then nothing I can do until I go to a better house with proper wiring.Slender wrote: ↑09 Oct 2025, 04:37This is very similar to a faulty UPS on your ISP's switch. What is your electrical system like? Do you have the ability to test the neutral/ground resistance?Kyousuke wrote: ↑08 Oct 2025, 22:10I also think I won’t find the real answer until I move to another country or at least to a better house, because I’ve already lived in two different houses and used two different ISPs.themagic wrote: ↑08 Oct 2025, 21:36@Kyousuke sry man...
no one knows...
- MaleGigolo
Why would u need to play against humans to figure out if your mouse, keyboard are delayed and that your game is spazzing out and colors are all washed up? How can a VPN reduce ping, which is your physical distance from the server? Lol. There is no such thing as "improvements" you either have this problem or not. If running VPN helps that usually means your routing is c*ap. I never said i have a working method? I don't know what is causing this problem otherwise i would have fixed it in 12-15 years.Kyousuke wrote: ↑08 Oct 2025, 21:33MaleGigolo wrote: ↑08 Oct 2025, 19:58Than you are not a very smart person if it takes you ages to plug off your ethernet and play few hours of bot games to determine if it is indeed internet problem or something else.Kyousuke wrote: ↑08 Oct 2025, 19:48To be honest, I’ve read quite a lot of posts here, but even now I still can’t clearly determine whether the cause is my electricity or my internet. However, the fact that everything works perfectly during a specific time, which is around midnight, when fewer people are using the network and electrical devices so makes me certain it’s related to one of the two.themagic wrote: ↑08 Oct 2025, 12:28There exist People who search for Ideal State and want become like Donk or some Streamer who have it perefect like always and huge advantage but this all is bullshit talk...
Many of People who rly suffer Issues here and these who I know...only just want know if everything was fairplay and want know if they was killed the right way and that everything was the correct way and without bullshit and so that it's explainable....
Many has Hitreg/Damage Issues and this is real and many feel like they are 0,5sec behind Enemy on Server without a Chance or against just some Randoms and don't matter what they try or do against that...and nothing like helps to counter that and them...and you feel like NOOB again...who can't do nothing against that ?
Is that what you start experience in the early morning and after 6 am ? And such Enemies ? Which seems are unkillable or some of them ? And you start to lose in many 1vs1 situations but where you was for 99% sure that it was and should be your KILL ? And where your muscle memory like messed up and don't works more like before and you can't adapt again for that moment ? Such kind of Issue ?
Or what kind of ISSUE and disadvantage you start to experience ? Pls try describe it some better if you can or just post some Clips where you feel and think is the problem the most for you and where you see it...
or you only start feel that your game becomes slow and nothing more than that ? and you feel that reason of why your KAD changes to bad and drop ?
You need first to clear figure out what kind of ISSUE you rly have and what you see on your Display and compare with others and post some examples....so we all can see the difference or just something...
Only after and maybe some People with knowledge can maybe and gonna help you with that and this Online Gaming Problem in COD, BF...
I’m quite sure about this, and it’s not just a “something feels off” kind of thing, because my K/D ratio is always extremely high at midnight. I move faster, react instantly, and have enough time to kill the enemy before they kill me. But in the morning, it’s completely different, I die before I can even do anything.
In COD, I’ve faced players with very high levels, yet I can easily beat them at night. But once it’s after 6 a.m., I can’t play like that anymore. I usually play with foreign players whose time zones differ from mine, so it’s not that I’m always playing with people who stay up late like me. I have image comparisons of my K/D in COD BO6 which is a game need speed to take down enemies, and in the midnight, it's 2x time higher than I play in the daylight.
I have image of my K/D in COD BO6, a game that heavily relies on speed to take down opponents as proof. and this can only happen when I play at midnight.
https://imgur.com/a/YkMehKq
Do you really think playing with bots is the same as playing online?
What we’re comparing here is the input delay between different types of gameplay — and I’ve already tested using a VPN to reduce ping as well as running my setup on a battery, both of which made improvements.
So what if both factors seem to help, and I can’t be entirely sure which one is the true cause?
There are plenty of people out there who have tested everything just like I did, yet none of them can pinpoint the real cause.
So tell me, how can you be so confident that your method is the accurate one?
amorou
Every game will feel like shit , image quality degrade too , and not like its lower quality or something , you cant really edit a video to make it look like its havining this issue , its hard to describeKyousuke wrote: ↑09 Oct 2025, 02:57Damn, that sucks. I’ve had the same issue too, no matter how much I upgrade components, input delay never goes away. Everything looks blurry when moving, even offline games. In Souls games, timing deflects is really difficult no matter how much I tried. at midnight my CS2 K/D is around 1.8, but during the day it drops to 1.0 or worse, but also I'm not pro at CS2. Now I just avoid games that are too influenced by input delay.
Unreazz
If you want my 2 cent. im pretty sure it's the internet. Here is a User named "Mello" if you search his older posts arround 2019 you read pretty much about it as he stated it as first out when everyone is still thinking that dirty electricity is corrupting there performances.
Sandy
Yes, the image quality has dropped significantly and the colors are not accurate. It seems that all the CPU calculations are disturbed.amorou wrote: ↑09 Oct 2025, 12:08Every game will feel like shit , image quality degrade too , and not like its lower quality or something , you cant really edit a video to make it look like its havining this issue , its hard to describeKyousuke wrote: ↑09 Oct 2025, 02:57Damn, that sucks. I’ve had the same issue too, no matter how much I upgrade components, input delay never goes away. Everything looks blurry when moving, even offline games. In Souls games, timing deflects is really difficult no matter how much I tried. at midnight my CS2 K/D is around 1.8, but during the day it drops to 1.0 or worse, but also I'm not pro at CS2. Now I just avoid games that are too influenced by input delay.
