Do not modify the timer resolution for games and again, I'll have to be the one to advocate for 8k every time, there is no reason against using it unless a specific game has problems. AFAIK timer res and polling rate have nothing to do with each other but even if we look at a theoretical situation, you can make the timer resolution as low as you like but it's a complicated solution.soul4kills wrote: ↑02 Oct 2025, 21:20It's good to limit your fps, but there's nothing wrong with being GPU bound, that's where you want to be. You don't want to be CPU bound, this is where input latency happens as your CPU will become backlogged with interrupts if CPU bound. As for the GPU, being GPU bound doesn't have a negative effect because it's only task is to generate frames, where the CPU handles a lot more unique tasks.-Always limit your fps, preferably to a number which will not leave you in a GPU bound situation, being in a constant GPU bottleneck will introduce additional inputlag. Ideally you should aim for stable fps twice as much as your refresh rate.
Also the mouse polling thing. 1000hz is enough. Windows handles interrupts at 1ms, and 0.5ms if you've modified your timer resolution. 1000hz is 1ms and 2000hz is 0.5ms. 8000hz in theory should be beneficial if current operating systems can handle it, but they can't, so it kind of is snake oil but not really. And it's not a game issue, it's an operating system issue. Your mouse would be generating more mouse reports than the Operating System can handle, so it gets backlogged and then that's where input latency happens.
And using a normal windows install is fine. Your suggestion is overkill. It's like saying, I have 20 apps on my computer, only 1 affects input latency, the solution is to not use the 20 apps at all. Yes windows does have some services and apps that affect input latency, but those are very few and can be solved by just closing or uninstalling/disabling it.
2025 Anti lag guide in getting new PC and hardware [video proof]
Hyote
Re: 2025 Anti lag guide in getting new PC and hardware [video proof and no schizo BS]
soul4kills
I suggest you do a bit more research on the relationship of timer resolution and how windows handles mouse interrupts. How you seem to think it works it incorrect. And no, polling rate issues isn't a game problem, it's an operating system problem. If a game doesn't perform well with 8k polling rate, it's because it's CPU bound.Hyote wrote: ↑02 Oct 2025, 22:46Do not modify the timer resolution for games and again, I'll have to be the one to advocate for 8k every time, there is no reason against using it unless a specific game has problems. AFAIK timer res and polling rate have nothing to do with each other but even if we look at a theoretical situation, you can make the timer resolution as low as you like but it's a complicated solution.
Hyote
Why do people even change the timer resolution?soul4kills wrote: ↑04 Oct 2025, 17:17I suggest you do a bit more research on the relationship of timer resolution and how windows handles mouse interrupts. How you seem to think it works it incorrect. And no, polling rate issues isn't a game problem, it's an operating system problem. If a game doesn't perform well with 8k polling rate, it's because it's CPU bound.Hyote wrote: ↑02 Oct 2025, 22:46Do not modify the timer resolution for games and again, I'll have to be the one to advocate for 8k every time, there is no reason against using it unless a specific game has problems. AFAIK timer res and polling rate have nothing to do with each other but even if we look at a theoretical situation, you can make the timer resolution as low as you like but it's a complicated solution.
Each system timer interrupt updates the system time. And since all frame limiters use sleep (i.e., the frame is already ready, but it can't be displayed immediately due to the limiter), sleep begins — say, for 5.5 ms.
If the timer resolution is set to 1 ms, then the system time will be updated 5 times, and the sleep will only end on the 6th update.
So instead of sleeping exactly 5.5 ms, the sleep will effectively last 6 ms, because system time is updated every 1 ms.
And as you can imagine, if the system time updated every 0.5 ms, the sleep would last exactly 5.5 ms, as intended.
This is why lower timer resolution improves frametime — because sleep duration becomes more accurate due to more frequent system time updates.
So, if you’re not using a frame limiter, or your game uses HYBRID WAITING (which most games presumably do, and for this method, 1 ms timer resolution is enough, and most games already request it), or BUSY WAITING,
then you don’t need to think about lowering the timer interrupt interval at all.
This was translated btw.
donger
mistake
donger
nope, ur wrong, you don't want to be bottlenecked either way cuz most games don't have reflexdonger wrote: ↑05 Oct 2025, 14:45soul4kills wrote: ↑02 Oct 2025, 21:20It's good to limit your fps, but there's nothing wrong with being GPU bound, that's where you want to be. You don't want to be CPU bound, this is where input latency happens as your CPU will become backlogged with interrupts if CPU bound. As for the GPU, being GPU bound doesn't have a negative effect because it's only task is to generate frames, where the CPU handles a lot more unique tasks.-Always limit your fps, preferably to a number which will not leave you in a GPU bound situation, being in a constant GPU bottleneck will introduce additional inputlag. Ideally you should aim for stable fps twice as much as your refresh rate.
Softhe
Can you check pm? Really interested in if you don't feel the stutters or if I've somehow missed something. I was running windows 10 for a long time but since switching to Windows 11 thinking the new mouse hid driver for high polling rate would be the last piece of the puzzle but alas I feel like it's still stuttering.Hyote wrote: ↑02 Oct 2025, 22:46
I've got 15 000h+ on cs and my cs2 is running incredibly well, and I don't think you configure anything that I don't including registry keys (unless you use something that is not on your github files- repo?).
24h2
Tried on both razer viper v2 pro & LGG LA-1
usb controller on core 9 (only cores 1-5 are handling cs2)
Direct cpu usb 2.0 controller (not going via chipset)
Avg fps on d2 map = 830 fps , 1% = 300 fps
Stripped windows with 0 bloat or unnecessary services etc
PG27AQN 360hz
donger
I suck balls in cs but holy shit this must be one of the lowest input lag machine on this forum and i guess there is still room for improvement since i haven't done advanaced tweaks like at all.
Hyote
Welcome to the club of people who keep repeating their famous one liner until they get bored of it. This mindset of advanced tweaks is just wrong. You have a system, there are metrics and also subjective feel that will decide what is the best. Personally I have pretty bad lag and desync in games but otherwise have hardware that can almost be called legacy at this point that can be tweaked to the high heavens. I wouldn't switch from this experience to one with less desync but also less optimizations.
donger
I mean i am happily open to doing advanced tweaks if there is a way to measure their impact, obviously i want lower input lag if that's even possible but your github is confusing at most no idea where to start tbh. And other sources are filled with some shady 'tweaks' which mostly sounds like a waste of time.Hyote wrote: ↑10 Oct 2025, 09:13Welcome to the club of people who keep repeating their famous one liner until they get bored of it. This mindset of advanced tweaks is just wrong. You have a system, there are metrics and also subjective feel that will decide what is the best. Personally I have pretty bad lag and desync in games but otherwise have hardware that can almost be called legacy at this point that can be tweaked to the high heavens. I wouldn't switch from this experience to one with less desync but also less optimizations.
- themagic
Show a full Deathmatch of you...I rly want look at that. Pls.Hyote wrote: ↑10 Oct 2025, 09:13Welcome to the club of people who keep repeating their famous one liner until they get bored of it. This mindset of advanced tweaks is just wrong. You have a system, there are metrics and also subjective feel that will decide what is the best. Personally I have pretty bad lag and desync in games but otherwise have hardware that can almost be called legacy at this point that can be tweaked to the high heavens. I wouldn't switch from this experience to one with less desync but also less optimizations.
And Play only AK47 or M4 or show Deagle only in Deathmatch or even in 5vs5 if you can...
but dont show clips where you cherry pick pls.
