It's NOT Your Gear or Electricity, It's YOU!
assombrosso
Re: It's NOT Your Gear or Electricity, It's YOU!
Post by assombrosso » 09 Jan 2025, 17:58
Its indeed you but its not the way u think it is. I will upload evidence one day if god allows me. Donk , hypetried, cemen bakin and some high elo players are abusing this trick
InputLagger
Post by InputLagger » 10 Jan 2025, 05:11
assombrosso wrote:
09 Jan 2025, 17:58
D0oc too? In faceit office in person
LeGiT
Post by LeGiT » 10 Jan 2025, 19:17
assombrosso wrote:
09 Jan 2025, 17:58
Waiting for that day bro
spkii
Post by spkii » 11 Jan 2025, 09:55
Did you guys tried with USB tethering via Iphone 5G? Im trying it now, 4 days works good. No router and ethernet disconnected to Computer.
SKILLEN
Post by SKILLEN » 11 Jan 2025, 18:54
spkii wrote:
11 Jan 2025, 09:55
Yes,i tried many times,no fix for me and my problem is only online.
Zwss98
Post by Zwss98 » 02 Nov 2025, 23:09
I think i figured it out , while emi is affecting input lag, our bodies able more than others tp build up static from anything around constantly, removed a blanket used to sit on while playing and noticed huge input lag improvement, changed polyester clothing with Cotton and also noticed an improvement, and so on
MK92
Post by MK92 » 03 Nov 2025, 04:25
So now its clothing and blankets? Cool placebo bro, so why is it working fine at night, did your blanket decide to not troll you with input lag at night, but only during the day?
In one of your previous posts, you said that your breathing is affeciting input lag (??), then in another thread that it was a SIM card causing that...so which is it now? Try to paint your room walls to pink, I heard this would help as well because it would reflect less EMI.
There are only two culprits, and none of them are magic:
-Are you having problems only in online games (offline mode in many esports games are literally still operated server-side)? Network problem.
-Are you having problems anywhere, including in BIOS? Electricity problem.
Static elecricity CANNOT cause any problems like that, even if you are having a PC built literally on a piece of cardbox without a case. If you have a PC on a carpet and you are wearing socks, then yes you can FRY your components by touching them, but this WON'T cause output/input lag lol, your PC simply wouldn't even turn on anymore.
Post by Slender » 03 Nov 2025, 13:45
Zwss98 wrote:
02 Nov 2025, 23:09
torsion fields, nothing else
Zwss98
Post by Zwss98 » 06 Nov 2025, 23:52
MK92 wrote:
03 Nov 2025, 04:25
Why I'm getting shocked too many times when touching my mouse or xbox controller and after that the input lag begins and sensitivity becomes uncontrollable
Kyousuke
Post by Kyousuke » 09 Nov 2025, 20:18
This sounds crazy, but lately I’ve been wearing long sleeves and even a coat when playing and I feel faster. Maybe it’s placebo, but my bullet in COD vs BF6 has faster than before, I kill enemy faster. I usually wore short sleeves.
My apartment isn’t grounded, so that might be a factor. I also once fixed input lag by using a battery instead of the power grid, but it only lasted five minutes.( cause my battery ran out)
I saw a thread of a guy in here said their body's positive charge affected input lag when touching metal desk, and he fixed it by grounding or sth, sounds wild, but maybe there’s a chance... I don't know anymore :o
