CS2 Margin Graph
vnb
Re: CS2 Margin Graph
Post by vnb » 16 Nov 2025, 14:22
SammYrai wrote:
16 Nov 2025, 13:27
vnb wrote:
16 Nov 2025, 05:53
this can only happen if your ISP is using PPPoE.... if you are on IPoE (DHCP) lease time is too long to get a new IP address if you disconnect the ethernet WAN port then reconnect it....
I just want to add that most (big) cable providers where you get a IPoE DHCP leased address will discard your lease reservation after a few hours of downtime, so if you want to change your IP you have good chances if you just unplug your modem over night.
yes, i know.
i was saying that because the "trick" Slender proposed only works for PPoE... As for each PPP session you will have a new IP so disconnecting / reconnecting instantly wan port only works for PPPoE because new session = new IP. While in IPoE DHCP you always have a lease time so you have to wait X amount of time before the server assign your router a new IP.
From the bunch of ISP i have used in the past that use IPoE DHCP the lease time was 6h at minimum so yeah... if someone absolutely want to change IP as you said; just unplug the router/modem before going to sleep.
Maybe some ISP have shorter lease time but from my knowledge i have never seen a lease time under 6 min. Most of the time it is a couple hours...
urikawa
Post by urikawa » 21 Nov 2025, 04:12
Hello i have done two things to get the same result ingame.
Installed qosmate on openwrt and set my ftth 1gb up and down internet connection to 230mb / 135 mb :'( and no more jitter and A+ bufferbloat and good result net perfect in cs2)
I have put this settings the night when everyone play and when i have the problem :p the day i have A+ bufferbloat with 800mb down and 400 up
The other problem was frame pacing for cs2 i used RTSS fps limiter to use the "Nvidia Reflex" option (added with 7.3.5 update) disabled in nvcp low latency mode.
I capped in RTSS the frame at 400fps i have 360Hz 1440x1080 resolution with alienware qdled.
My setup is capable of doing 800 fps at that resolution and 320 fps for the 1% low, but the hitreg was bad with uncapped fps.
The feeling when playing is the best with this setup for my config with rtss.
You need to add to launch command in steam to allow rtss cap -allow_third_party_software cs2 launcher.
i also have setup this for battlefield 6 the hitreg is also better in feeling.
vnb
Post by vnb » 21 Nov 2025, 16:34
urikawa wrote:
21 Nov 2025, 04:12
what's your gpu / mobo / cpu? you are saying that you have bad "frame pacing in cs2"... BTW the game is completely broken not only for you but everybody else... Nobody have good frame pacing in cs2 even with rtx4090 and 9800x3d...
Also pretty interesting that you say uncapped fps give you worse hitreg because for me it is the exact opposite ? But i prefer to play with capped FPS because i have higher 1% low with capped FPS.
2 of my friends say capped FPS feels better hitreg and 2 other feels like uncapped FPS feels better for hitreg (all lvl10 faceit) so very inconsistent; lol. Same thing on twitter pretty much 50/50 on capped vs uncapped.
the game definitely still needs a lot of works even 2 years after it was released it still feels like beta, lol. In CSGO the dev took like 5-6 years before the game felt "close to perfect". so i guess we still have at least 3 years of waiting before having a more polished game, unfortunately...
urikawa
Post by urikawa » 22 Nov 2025, 09:42
My config is pretty optimize for cs2 i play since half life mod of cs and i was a lan player too
Before i would have agree for different setup i have tested so much now and the better is this own you could give a try :) bios is tuned also
I can give all my optimization and bios settings if you need
Router is VEP1400-X DELL 8 Core with openwrt 24.10.4 and qosmate
CPU: AMD Ryzen 7 9800X3D with Alphacool Eisbaer Pro Aurora 420 AIO
MOTHERBOARD: ROG CROSSHAIR X870E APEX
PSU: ATX 3.1 - NZXT C1000 GOLD
GPU: MSI RTX 5080 TRIO OC GAMING 16G
RAM: Lexar 6200Mhz CAS26
Infinity Fabric 2100
Storage: MSI SPATIUM M580 PCIe 5.0 NVMe 2TB
Network: Emulex 10GB
Display: Dell Alienware AW2725DF - 360Hz 2K QDLED
OS: Windows 11 IoT Enterprise LTSC (Debloated with NTLite)
Keyboard : Wooting 80HE @ 8 kHz
Mouse: OP1 8khz v2
Headset: Logitech G PRO X 2 LIGHTSPEED
Mousepad: Artisan Ninja FX Zero
Sensitivity: Windows 2 - Ingame 0.5 @ 1600 DPI
Launch options: -allow_third_party_software
FPS Heaven CS2 Benchmark 1% low 320 fps 1440x1080 4:3 Strech
https://www.waveform.com/tools/bufferbl ... 5337800b2c
