So, you fixed the problem and you will never return to this forum again?
UPDATE 2 | Fixed input lag and floaty mouse with UPS
- Roxtar
Re: Partially fixed input lag and floaty mouse
If you read the thread title I said partially fixed, I still suspect something is going on, maybe faulty components due to bad electricity exposure, maybe some kind of high frequency interference not being filtered by the UPS... It can be a lot of things. I don't tunnel vision on only 1 cause.
Have you even tried a double conversion UPS to be so sure that the solution is something else?
[email protected]
The specification VFI-SS-111 tells you it is not just a random 10€ socket filter.Slender wrote: ↑28 Nov 2025, 03:34u never fix it by socet filter
I'm telling you this only because I want to save you time and money.
I also experience improvement from connecting something metal between the PC and the socket, but believe me, a real fix costs a couple of bucks.
keep installing useless things between your pc and the socet.
Can you affored the money for VFI-SS-111 UPS?
Only for you again:
The filtering in a VFI-SS-111 refers to the operation of an online double-conversion UPS (Uninterruptible Power Supply) system classified according to the DIN-EN 62040-3 standard. This means it offers the highest level of protection through double voltage conversion (AC to DC and back). The output voltage and frequency are completely isolated from the input, resulting in a constant and clean output current free of interference.
I find it very sad that you ridicule a good approach to solving the problem and contribute nothing constructively to finding a solution, except to let the thread drift off-topic. I thought we had the same goal.
- Slender
trying 3 different ups with double conversion + toroidal isolation transformer with virtual ground. + 100500 types of filters.Roxtar wrote: ↑28 Nov 2025, 04:49If you read the thread title I said partially fixed, I still suspect something is going on, maybe faulty components due to bad electricity exposure, maybe some kind of high frequency interference not being filtered by the UPS... It can be a lot of things. I don't tunnel vision on only 1 cause.
- Slender
I won't recommend anything that doesn't work. In 15 years, I've tried more things than you'll ever try in a lifetime. So I'm just saving people time.[email protected] wrote: ↑28 Nov 2025, 05:16The specification VFI-SS-111 tells you it is not just a random 10€ socket filter.Slender wrote: ↑28 Nov 2025, 03:34u never fix it by socet filter
Only for you again:
- Slender
The only thing that is available to everyone and free of charge is moving the PC with the monitor around the room. Believe me, this will have a much greater effect than any UPS you can install.
[email protected]
No one is recommending something. We are just testing and posting about it.
Which UPS have you tested?
- Slender
macan mac 1000-3000 (isolated neutral)[email protected] wrote: ↑28 Nov 2025, 09:41No one is recommending something. We are just testing and posting about it.
skat ups 3000 (best for elim. harmonic)
apc smart ups online 1000.
system TN-C (testing with / without PE).
[email protected]
macan mac 1000-3000 (isolated neutral) don´t have the VFI-SS-111 specification
skat ups 3000 (best for elim. harmonic) don´t have the VFI-SS-111 specification
apc smart ups online 1000. have the specification. it was really in online mode?
system TN-C (testing with / without PE). For me it make no difference.
- Slender
fix found guys!!!
all order ups with VFI-SS-111!
Chief, close forum.
Chief, close forum.
