Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
[email protected]
Post
by [email protected] » 28 Nov 2025, 10:42
Slender wrote: β28 Nov 2025, 10:27
fix found guys!!!
all order ups with VFI-SS-111!
Chief, close forum.
No one said itΒ΄s the ultima fix.
Are you sure the "apc smart ups" was online and
NOT line?
There exist also line versions on the market.
Post
by Slender » 28 Nov 2025, 13:33
[email protected] wrote: β28 Nov 2025, 10:42
fix found guys!!!
Chief, close forum.
NOT line?
SMX1000I
that is line interactive
anyway, that all is same, just unplug ups, and if you not feel instantly fix, that is not socet, because in another apartment same pc with same psu work perfectly.
[email protected]
Post
by [email protected] » 28 Nov 2025, 14:27
Slender wrote: β28 Nov 2025, 13:33
SMX1000I
No it is not the same! There is a reason why some UPS get a specification VFI-SS-111 and other not!
In summary, you didn't have a UPS with the VFI-SS-111 specification and therefore cannot participate in the discussion on this topic!
Please inform you what specifications, classifications and standards are and what they are used for.
The time will tell, if UPS with the VFI-SS-111 specification is a possible solution.
Post
by Slender » 28 Nov 2025, 14:30
[email protected] wrote: β28 Nov 2025, 14:27
SMX1000I
hahahah, ok, vfi ss is double conversion, thats all. all another is your hallucinations.
sulaemulae
Post
by sulaemulae » 28 Nov 2025, 19:52
I know a guy claiming 'Richard Grays power company (RGPC 400 PRO) ' fixed by a lot for him. Desyncs, monitor and controls.
Post
by Slender » 28 Nov 2025, 21:12
sulaemulae wrote: β28 Nov 2025, 19:52
ahhahahahahaahahhahah
- m84561484330_2.jpg (138.55 KiB) Viewed 5441 times
Roxtar
Post
by Roxtar » 29 Nov 2025, 08:53
fix found guys!!!
Chief, close forum.
Post
by Slender » 29 Nov 2025, 08:59
Roxtar wrote: β29 Nov 2025, 08:53
fix found guys!!!
Chief, close forum.
clown, read about electromagnetic field
Roxtar
Post
by Roxtar » 29 Nov 2025, 09:03
Slender wrote: β29 Nov 2025, 08:59
fix found guys!!!
Chief, close forum.
You are the only clown here, you came to my thread just to laugh on us and with 0 intention on adding to the subject, I've said multiple times we might not have the same problem, there are other threads you can participate in that discuss imaginary interferences in the air, this is clearly not your thread and you are not helping.
Post
by Slender » 29 Nov 2025, 09:10
Roxtar wrote: β29 Nov 2025, 09:03
fix found guys!!!
Chief, close forum.
My intention is to tell you that you are doing useless bullshit. The fact that we all have the same problems is clear from the fact that we're all gathered here on the forum with exactly the same problem. The only thing that might differentiate us is the source of the problem (the type may be different), but the frequency that emits it is the same.
