Ok, later today. Firstly I was interested in feedback.rekaa02511 wrote: ↑18 Dec 2025, 14:18Can you tell us more what this does in the background? I think many people here are sceptical with no information at all.
Try my new app to fix input lag (cs2_timer_fix_by_yam1ke)
Re: Try my new app to fix input lag (cs2_timer_fix_by_yam1ke)
Oh, sorry, I forgot that I owe you something! Ok, I will post nothing then. Anyone who really wants can get info in my telegram group where I share details. Try not to choke on your own bile man)
I don’t understand this people just download random programs, which could even be cheats or anything else? And there’s no source code anywhere? Plus, I don’t understand this kind of person who talks to the members here like this I would delete this topic.
I was ready to share knowledge, but source code is my intellectual property. If I violate your rules, you can delete me, no problem. But I don't care about people who think I something owe them with toxic tone. You can always check the app for viruses, injectors, hooks and so on, its your right. But I guess, you find nothing illegal.
Anyone can say this, and in my opinion the code was written by chatgpt, so you don’t really have much intellectual property in it. I don’t think you’re a programmer, but at least you could show 1–2 insights into what does what, what this program actually is, what you manipulate with it, what advantage it gives you over other players. You should also admit that this is not right this way. VirusTotal or any antivirus may not necessarily detect a virus in it, but it can still be malicious. By the way, you could steal anything with it, from a keylogger to pretty much anything.
Since OP shared having a "config.ini", that makes me believe it's a program similar to one from a private Russlan community, specifically called SECRET-TWEAK. I also made a program like that and shared a very basic version on GitHub that also had a config.ini. Since then I made a much more complex version but kind of stopped working on it because there were a lot of downsides to using it. Still it's an interesting concept.
App has many internal settings developed by me. It's just convenient to use presets to set this settings, than trying to explain everyone what it means.You can always change them on the fly in the app as you want. And even save your own by pressing F11Hyote wrote: ↑18 Dec 2025, 23:37Since OP shared having a "config.ini", that makes me believe it's a program similar to one from a private Russlan community, specifically called SECRET-TWEAK. I also made a program like that and shared a very basic version on GitHub that also had a config.ini. Since then I made a much more complex version but kind of stopped working on it because there were a lot of downsides to using it. Still it's an interesting concept.
PS Russlan SECRET TWEAK
