No FPS gaming possible
LaggyTyp
Re: No FPS gaming possible
Post by LaggyTyp » 23 Dec 2025, 09:08
Screenshot (1218).png (49.62 KiB) Viewed 4765 times
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:11:50 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DIRECTOR
OS version: Windows 11, 10.0, version 2009, build: 26100 (x64)
Hardware: System Product Name, ASUS
BIOS: 2204
CPU: GenuineIntel 12th Gen Intel(R) Core(TM) i9-12900KF
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 32613 MB total
CPU SPEED
Reported CPU speed (WMI): 320 MHz
Reported CPU speed (registry): 3187 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 6806,80
Average measured interrupt to process latency (µs): 5,647159
Highest measured interrupt to DPC latency (µs): 6802,80
Average measured interrupt to DPC latency (µs): 3,234563
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 1619,340132
Driver with highest ISR routine execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total ISR routine time (%): 0,002920
Driver with highest ISR total time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in ISRs (%) 0,002924
ISR count (execution time <250 µs): 250870
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 2
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 4076,505177
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 591.59 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,084939
Driver with highest DPC total execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in DPCs (%) 0,227004
DPC count (execution time <250 µs): 1747021
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 112
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 27
DPC count (execution time >=4000 µs): 1
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: startmenuexperiencehost.exe
Total number of hard pagefaults 859
Hard pagefault count of hardest hit process: 684
Number of processes hit: 13
PER CPU DATA
CPU 0 Interrupt cycle time (s): 63,177919
CPU 0 ISR highest execution time (µs): 1619,340132
CPU 0 ISR total execution time (s): 0,332324
CPU 0 ISR count: 250869
CPU 0 DPC highest execution time (µs): 4076,505177
CPU 0 DPC total execution time (s): 24,991541
CPU 0 DPC count: 1528371
CPU 1 Interrupt cycle time (s): 5,025051
CPU 1 ISR highest execution time (µs): 1,555695
CPU 1 ISR total execution time (s): 0,000004
CPU 1 ISR count: 3
CPU 1 DPC highest execution time (µs): 3235,653279
CPU 1 DPC total execution time (s): 0,026161
CPU 1 DPC count: 11425
CPU 2 Interrupt cycle time (s): 5,195791
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 268,822717
CPU 2 DPC total execution time (s): 0,052546
CPU 2 DPC count: 21209
CPU 3 Interrupt cycle time (s): 5,107002
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 3149,249451
CPU 3 DPC total execution time (s): 0,029582
CPU 3 DPC count: 8631
CPU 4 Interrupt cycle time (s): 5,606047
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 64,376530
CPU 4 DPC total execution time (s): 0,043891
CPU 4 DPC count: 16183
CPU 5 Interrupt cycle time (s): 5,213546
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 63,064010
CPU 5 DPC total execution time (s): 0,028304
CPU 5 DPC count: 8269
CPU 6 Interrupt cycle time (s): 5,274798
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 3020,702542
CPU 6 DPC total execution time (s): 0,045764
CPU 6 DPC count: 11922
CPU 7 Interrupt cycle time (s): 5,070198
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 269,460307
CPU 7 DPC total execution time (s): 0,031557
CPU 7 DPC count: 8198
CPU 8 Interrupt cycle time (s): 5,999243
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 266,135237
CPU 8 DPC total execution time (s): 0,101334
CPU 8 DPC count: 23320
CPU 9 Interrupt cycle time (s): 5,530172
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 319,689677
CPU 9 DPC total execution time (s): 0,081679
CPU 9 DPC count: 21342
CPU 10 Interrupt cycle time (s): 5,512990
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 267,768434
CPU 10 DPC total execution time (s): 0,070279
CPU 10 DPC count: 18200
CPU 11 Interrupt cycle time (s): 4,823932
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 88,511767
CPU 11 DPC total execution time (s): 0,117119
CPU 11 DPC count: 23852
CPU 12 Interrupt cycle time (s): 5,291924
CPU 12 ISR highest execution time (µs): 0,0
CPU 12 ISR total execution time (s): 0,0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 3093,961406
CPU 12 DPC total execution time (s): 0,050773
CPU 12 DPC count: 12867
CPU 13 Interrupt cycle time (s): 5,271624
CPU 13 ISR highest execution time (µs): 0,0
CPU 13 ISR total execution time (s): 0,0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 67,306244
CPU 13 DPC total execution time (s): 0,041386
CPU 13 DPC count: 10848
CPU 14 Interrupt cycle time (s): 5,102173
CPU 14 ISR highest execution time (µs): 0,0
CPU 14 ISR total execution time (s): 0,0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 3066,883276
CPU 14 DPC total execution time (s): 0,048021
CPU 14 DPC count: 12634
CPU 15 Interrupt cycle time (s): 5,111188
CPU 15 ISR highest execution time (µs): 0,0
CPU 15 ISR total execution time (s): 0,0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 70,741763
CPU 15 DPC total execution time (s): 0,040204
CPU 15 DPC count: 9891
darkbebe
Post by darkbebe » 24 Dec 2025, 07:34
LaggyTyp wrote: ↑
23 Dec 2025, 06:31
- Everyone can see me before I can
- Everyone can shoot faster than I can
- I feel extremely disadvantaged, even though everything should be perfect
The problem cannot be the internet.
Every noob makes me sick.
There has to be a solution, right? I watch others on Twitch: they have way, way, way more time to react than I do. My opponents don't even see them. It's like he's a ghost. Everyone's completely focused on me the whole round.
what game are you playing? if it's cs 2 and you re playing 4:3 streched 1280x 960 or 1280x1024 , just try 1440 streched or 16:9 it will help to reduce the speed of your opponents. it seems that the more your game is horizontal distorted , the more the speed will be insane & getting ferrari peeks. i still have my awful hit register problem but since i changed resolution i have reduced the ferrari peeks by 70%
darkbebe
Post by darkbebe » 24 Dec 2025, 07:46
LaggyTyp wrote: ↑
21 Oct 2025, 04:36
I'm stuck here.
I'm trying to play BF6, but it's impossible. I log into the game and get bombs (normal shots) that destroy me instantly. No time to react.
I ordered Starlink. It works perfectly. I can shoot normally and get shot at normally. But I can't guarantee a 360° view for Starlink because I don't have access to the roof. Since ~180° is obscured, it keeps losing connection.
Docsis Internet: Forget it (Vodafone admits to errors they can't fix. Termination without notice is currently in progress)
VDSL: According to the neighbor, sometimes good, sometimes bad
4G/5G: Forget it!
Starlink: PERFECT, but it has to go on the roof (forget it)
I'm boiling with rage.
and vpn doesn't change anything? same problem? :(
at least you have the hope of starlink ! maybe you can change your location with a better view on the satellite you need to aim. for me starlink doesn't work good yet i 'm on a island (reunion island) with a lot of jitter and instability .
LaggyTyp
Post by LaggyTyp » 24 Dec 2025, 08:30
I'm playing Battlefield 6.
VPNs like ExitLag make it worse. At best, it's normal, but no better than without one. Most of the time, it's worse.
I'm playing normally at 1440p.
G-Sync (Driver)
V-Sync (Game)
ULM disabled (Driver)
Reflex On + Boost (Game)
FPS-Limit disabled (Driver+Game)
I suspect too much is happening on "Core 0."
LaggyTyp
Post by LaggyTyp » 24 Dec 2025, 09:36
I used GoInterruptPolicy.exe to distribute the following devices across other cores.
nVidia 3080TI = All E-Cores (8)
Realtek 8125B (PCIe) = Core 9 + Core 11 + Core 13 + Core 15
Sound BlasterX G6 = Core 3 + Core 5
Idle:
Screenshot (1228).png (63.81 KiB) Viewed 4585 times
After a round of Battlefield 6
Screenshot (1229).png (62.13 KiB) Viewed 4585 times
Code: Select all
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for  0:27:02  (h:mm:ss) on processors 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14 and 15.
SYSTEM INFORMATION
BIOS:                                                 2204
Logical processors:                                   24
Processor groups:                                     1
Processor group size:                                 24
RAM:                                                  32613 MB total
CPU SPEED
Highest measured interrupt to process latency (µs):   326,50
Average measured interrupt to process latency (µs):   5,079390
Highest measured interrupt to DPC latency (µs):       213,60
Average measured interrupt to DPC latency (µs):       2,353250
 REPORTED ISRs
Highest ISR routine execution time (µs):              42,110762
Highest reported total ISR routine time (%):          0,003005
Total time spent in ISRs (%)                          0,003005
ISR count (execution time <250 µs):                   543147
ISR count (execution time 1000-2000 µs):              0
REPORTED DPCs
Highest DPC routine execution time (µs):              511,460621
Driver with highest DPC routine execution time:       ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%):          0,046971
Total time spent in DPCs (%)                          0,058085
DPC count (execution time <250 µs):                   1488864
DPC count (execution time 500-10000 µs):              28
DPC count (execution time 1000-2000 µs):              0
DPC count (execution time 2000-4000 µs):              0
DPC count (execution time >=4000 µs):                 0
Process with highest pagefault count:                 explorer.exe
Total number of hard pagefaults                       88360
Hard pagefault count of hardest hit process:          57306
Number of processes hit:                              31
 PER CPU DATA
CPU 0 Interrupt cycle time (s):                       57,311534
CPU 0 ISR highest execution time (µs):                42,110762
CPU 0 ISR total execution time (s):                   1,169787
CPU 0 ISR count:                                      543099
CPU 0 DPC highest execution time (µs):                450,126137
CPU 0 DPC total execution time (s):                   21,130490
CPU 0 DPC count:                                      1035467
CPU 1 Interrupt cycle time (s):                       9,860436
CPU 1 ISR highest execution time (µs):                0,0
CPU 1 ISR count:                                      0
CPU 1 DPC highest execution time (µs):                511,460621
CPU 1 DPC total execution time (s):                   0,079340
CPU 1 DPC count:                                      29380
CPU 2 Interrupt cycle time (s):                       8,236915
CPU 2 ISR count:                                      0
CPU 2 DPC highest execution time (µs):                86,130217
CPU 2 DPC total execution time (s):                   0,158596
CPU 2 DPC count:                                      78980
CPU 3 Interrupt cycle time (s):                       8,788828
CPU 3 ISR highest execution time (µs):                9,517728
CPU 3 ISR total execution time (s):                   0,000210
CPU 3 ISR count:                                      48
CPU 3 DPC highest execution time (µs):                112,424851
CPU 3 DPC total execution time (s):                   0,088426
CPU 3 DPC count:                                      30890
CPU 4 Interrupt cycle time (s):                       9,012219
CPU 4 ISR count:                                      0
CPU 4 DPC highest execution time (µs):                101,535613
CPU 4 DPC total execution time (s):                   0,07950
CPU 4 DPC count:                                      25637
CPU 5 Interrupt cycle time (s):                       9,369711
CPU 5 ISR count:                                      0
CPU 5 DPC highest execution time (µs):                77,098211
CPU 5 DPC total execution time (s):                   0,074260
CPU 5 DPC count:                                      22433
CPU 6 Interrupt cycle time (s):                       9,383525
CPU 6 ISR count:                                      0
CPU 6 DPC highest execution time (µs):                509,025416
CPU 6 DPC total execution time (s):                   0,087431
CPU 6 DPC count:                                      28254
CPU 7 Interrupt cycle time (s):                       9,642427
CPU 7 ISR count:                                      0
CPU 7 DPC highest execution time (µs):                77,893630
CPU 7 DPC total execution time (s):                   0,085117
CPU 7 DPC count:                                      23430
CPU 8 Interrupt cycle time (s):                       10,294687
CPU 8 ISR count:                                      0
CPU 8 DPC highest execution time (µs):                76,816756
CPU 8 DPC total execution time (s):                   0,092439
CPU 8 DPC count:                                      30181
CPU 9 Interrupt cycle time (s):                       10,277377
CPU 9 ISR count:                                      0
CPU 9 DPC highest execution time (µs):                508,771572
CPU 9 DPC total execution time (s):                   0,091858
CPU 9 DPC count:                                      24545
CPU 10 Interrupt cycle time (s):                       11,463806
CPU 10 ISR count:                                      0
CPU 10 DPC highest execution time (µs):                150,153750
CPU 10 DPC total execution time (s):                   0,143718
CPU 10 DPC count:                                      29762
CPU 11 Interrupt cycle time (s):                       11,279473
CPU 11 ISR count:                                      0
CPU 11 DPC highest execution time (µs):                94,501726
CPU 11 DPC total execution time (s):                   0,144714
CPU 11 DPC count:                                      29519
CPU 12 Interrupt cycle time (s):                       8,949321
CPU 12 ISR count:                                      0
CPU 12 DPC highest execution time (µs):                81,208660
CPU 12 DPC total execution time (s):                   0,090262
CPU 12 DPC count:                                      26714
CPU 13 Interrupt cycle time (s):                       9,006128
CPU 13 ISR count:                                      0
CPU 13 DPC highest execution time (µs):                109,931283
CPU 13 DPC total execution time (s):                   0,087279
CPU 13 DPC count:                                      22623
CPU 14 Interrupt cycle time (s):                       8,871155
CPU 14 ISR count:                                      0
CPU 14 DPC highest execution time (µs):                56,146847
CPU 14 DPC total execution time (s):                   0,093853
CPU 14 DPC count:                                      27423
CPU 15 Interrupt cycle time (s):                       8,756995
CPU 15 ISR count:                                      0
CPU 15 DPC highest execution time (µs):                507,171949
CPU 15 DPC total execution time (s):                   0,088596
CPU 15 DPC count:                                      23654
Am I on the right track? Perhaps there really is too much going on on core 0, which is disrupting my gameplay? What else can I optimize?
Post by Slender » 24 Dec 2025, 10:46
no way. my values lowes as possible.
1isr mouse / 50dpc video while game.
same issue like you.
stop waste time on it.
LaggyTyp
Post by LaggyTyp » 24 Dec 2025, 11:44
What could that mean?
Screenshot (1231).png (11.94 KiB) Viewed 4558 times
MK92
Post by MK92 » 24 Dec 2025, 13:08
It means that you have a shit ISP - which is known in your country for being shit and causing problems - and on top of it, you have an old coax connection, just like people told you on pages 1-2 several months ago, and you still try to fix this with some bullshit placebo stuff.
When will you finally accept that this is NOT software or PC related, and that you will NOT fix this? Only one option - move to a place where there is fiber connection, and get a better ISP...it could also be shitty electricity interference, in combination with shit coax cable and ISP.
Now try to insert more CMD commands and do 1000 more software tests, and change 1000 more settings in windows.
LaggyTyp
Post by LaggyTyp » 24 Dec 2025, 13:16
I switched to VDSL and O2 is considered excellent here.
MK92
Post by MK92 » 24 Dec 2025, 13:32
It's still old copper cable from 25 years ago. Go and take your PC to some other house where there is fiber connection and clean electrcitiy, and you will see how it will work perfectly.
